Question about Nokia 6500 Slide Cellular Phone
Bt paragon 650
Stuck in test mode
BT SYNERGY 5500 HANDSET IN TEST MODE
Having changed the batteries on my bt synergy 5500 trio it now displays that it is in test mode. How can I activate my phone so that I can receive and make calls
Oct 02, 2012 | Lands Phones
Additional handset on BT Synergy 6500 phone is stuck on 'Test Mode'
is possble to use 8 bt 6500 hand phones via 2 base unit on the one bt line
Feb 28, 2012 | GE 25942GE2 Cordless Phone System
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
http://waterheatertimer.org/Paragon-timers-and-manuals.html
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
My paragon timer4001-ov runs but will not trip on/ off trippers if this cannot be repaired what would be a good replacement for 120 volt supply
I don't see the 4001-ov in the Paragon spec sheet
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
To test the general condition of your Paragon timer, use the manual override.
If the manual override works perfectly, then you may need new tripper pins.
The Paragon 4000 series uses X2772 tripper pin.
Google search Paragon X2772 tripper turns up prices of $9 for a pair of trippers
A simple 120V replacement timer is the Intermatic T-101
For outdoor, use the T-101R 'R' for raintight
Lowes usually has the T-101 on the store shelf and they sell the T-101R online
http://www.lowes.com/pd_29405
http://www.aplussupply.com/intermatic/timer.htm
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Oct 28, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Message light on my bt paragon 650 phone answering machine, will not go out after deleting all the mrssages.
You may have a text message come through. Press the TEXT button to read then options to delete.
Mar 20, 2010 | Lands Phones
BT GPS module RBT-2100LP stuck in pair mode
royaltek faq advises to disconnect battery for 3 days to reset device
Mar 17, 2010 | RoyalTek RBT-2100 GPS Receiver
My BT Paragon 450 corded phones has been dropped,it appears to be working okay but has no ringing tone.
I was fiddling around with my computer phone connections and the dial tone came on again.
Nov 26, 2008 | Lands Phones
INstallation instruction for Jabra BT350 with a Palm 650
Hold the button on the flat side (power button) until light stays on. It is now in discover mode. Next, set your phone to look for BT devices. The passcode is 0000. That should be it.
Apr 23, 2007 | Jabra BT350 Wireless Headset
Nokia 6500 Slide Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
