Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint 1200 wm72
My washing machine is coming up with E14 see manual and needless to say i have no manual. I would be grateful if somebody could tell me what E14 is please. Thank You Gilly
  • Gillygurl Aug 15, 2007
    Thank you for you help it was much appreciated. Gillian
  • Anonymous Mar 22, 2014
    Door stays locked e14 error code
    Novelist:
    Champion:
  • 244 Answers
Its your heater element that is faulty more than likely will need replacing m8
Posted on Aug 15, 2007
  • peter gittos
    peter gittos Aug 15, 2007
    its ok love happy to be of help to u hope it all goes well
SOURCE:
My hotpoint washing machine model wm72 ultima 1200 on the sreen it comes up asking to check dischare hose having done this several times it keeps comeing back to check the same thing the hose is not...
simon, i would take a guess on the sump being blocked up.
remove rear inspection panel, you will see the drain pump on the left with a black hose coming out of it going up and attaching onto the drum by a clamp.
tilt the machine forward and put a basin underneath. using pair of vice grips remove that clamp and pull the sump down and off. hopefully this will be full of debris, clean out and put back together.
should do the trick.
great old machine that, wont get one like it again.
Mar 17, 2011 | Hotpoint Washing Machines
Electric circuit diagram needed
I am afraid that you can not get a wiring diagram for these washers, the only chance you have got is to contact Hotpoint/creda and see if they have a service manual for sale.
Go to www.hotpoint.co.uk
Plz rate my solution.
Thanks
Jan 23, 2009 | Creda Washing Machines
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
No handbook
Try finding the handbook in here, if that is not available call them by phone.
Check also WM72 Quick Guide.
Jan 15, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima 1200 Wm72 Erroe E14
I think you will find that the error relates to the heating element.
E14 on the Hotpoint WM75E means that there is a problem with the water heating.
Jun 05, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
ERROR MESSAGE ON SCREEN STATES CHECK OUTLET PIPE E15
It probably needs a new Pump, the wm72 has what they call a magnet pump and they can give false readings to the programme. Anew pump will cost sround 20 GBP. For an engineer to do it will cost around 50 GBP.
Nov 18, 2007 | Hotpoint Aquarius WD640 Front Load...
Soap dispenser
Some softeners are too thick, you could dilute this with water before you add to the machine. Note: Your tube to the softener drawer could be loose or something, you could check this by taking the top of the machine off to examine. Actually simple.
Oct 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
442 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
