Question about Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
Ram slot shprt - Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
    Brigadier General:
  • Intel Master
  • 3,400 Answers
DETAILS,DETAILS
Posted on May 02, 2013
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
Dell Inspiron B130- Memory installation in second slot
RAM modules in laptops are secured by spring clips on both sides of the RAM module.
To release the RAM module press the clips away from the RAM module and the RAM module will pop up at an angle. You can then pull the RAM module away from the memory slot.
Insert the RAM module in the slot, push it into th slot and then press the RAM module down until the clips on the side lock onto the RAM module.
Jun 04, 2012 | Dell Inspiron B130 Notebook
Only one ram slot works
Latops have two RAM slots and they usually are located on the bottom of the laptop.
If you see only one RAM slot on the bottom of your laptop then this is RAM slot is number 2, the other RAM slot is located under the keyboard and this memory slot is RAM slot number 1 and the first RAM module in installed in this RAM slot.
Jun 01, 2012 | Computers & Internet
My 2nd memory slot for ram is not working can this be repaired?
Beforeyouassume the 2nd RAM slot is faulty check the following.
When instaling RAM in the 2nd memory slot this RAM may not be compatible with the RAM in the 1st memory slot or the RAM may be faulty.
Try and use the same make, speed and size RAM modules.
If the RAM slot is faulty, chances are it cannot be repaired.
Aug 27, 2011 | Computers & Internet
I have bought a 2x2 gig ram upgrade from 1 gig for my computer. I have an msi p965 motherboard where should I plug th two ram modules into. I have a choice of two orange or two green inputs? what are your...
put the largest ram closest to CPU central processing unit make sure that the ram are of the same brand/type some motherboards only accept a certain brand/type
Nov 09, 2010 | MSI P965 Platinum (7238010) Motherboard
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
I can't get my Acer aspire e380 to accept another
How many slots for RAM in the motherboard?
If there are 4 slots, are the slots equally-spaced, or are they located as two pairs of slots, with a gap between the 3rd and 4th slot?
Some computers _REQUIRE_ RAM only in the 1st and 3rd slots, or only in the 2nd and 4th slots.
Some computers "beep" when 3 out of the 4 RAM slots are populated.
Some computers require the size of the RAM in the 1st slot to match the size of the RAM in the 3rd slot,
and the size of the RAM in the 2nd slot to match the size of the RAM in the 4th slot.
Does your computer "beep" when one stick is in the first slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the second slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the third slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the fourth slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the first slot and a matching stick is in the third slot, and the other slots are empty? How much RAM on those sticks?
Jan 23, 2010 | Acer Aspire E380-UD420A (ASE380-UD420A)...
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
Can not find second ram chip
Remove both pieces of ram (mark them with a felt tip marker so you know which one is which), and clean the contacts on the ram and the slots with a pink pencil eraser. Be gentle though, you don't want to remove the gold on the contacts, just remove the oxidation and make 'em bright again. You can shape the eraser to fit the slot with a sharp knife - and be sure to remove the eraser debris from the slots with a soft brush (dry toothbrush is good) . If still no good try this:
  1. Remove both pieces of ram.
  2. insert the second piece of ram in the first slot (leave the other slot empty) If the second piece of ram is detected, then the ram is good, and the second slot is likely the problem. If the ram is not detected, then the second stick of ram is the problem. Confirm this by putting ram stick 1 into slot 2. If the known good stick of ram (1) doesn't work in slot 2, then the slot is dead. If this is the case, get a larger stick of ram for slot 1. Let me know if this helps or not.
Aug 08, 2009 | Computers & Internet
Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
18 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
