Question about Kyocera FS-2020D Laser Printer
Enter kyocera maintenance mode - Kyocera FS-2020D Laser Printer
What is machine failure C7101?
if you referring to color copier this means you having black drum or black dv unit error.
you can try to reset it by entering the maintenance mode and reset the disable function sometimes it works.
login to maintenance mode:
1087 1087
Start
906
Start
Highlight Execute
Start.
Turn machine OFF/ ON
Good Luck!
Apr 19, 2016 | Kyocera Office Equipment & Supplies
How can i reset the code error sc543 for kyocera fsc1020mfp
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Oct 02, 2014 | Kyocera Office Equipment & Supplies
Kyocera maintenance kit reset
You can access the following by hitting the menu key
1. Enter the maintenance mode [>>Maintenance].
2. Press the OK key. [>>Maintenance?] will be displayed.
3. Press the OK key twice. The counter for each component is reset immediately.
Aug 26, 2014 | Kyocera FS-1370DN
HOW REMOVE IT FROM THIS Defective power supply ERROR
Reset C6400 ERROR
turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Select Service setting using
the up/down cursor keys.
While pressing the start key and the # key,
press the enter key..........Maintenance mode is entered.
Select Maintenance mode using
Press the enter key.
Enter the maintenance item
number U163 using the up/down keys.
Select Execute using the up/down cursor keys.
Press the enter key. The fusing problem data is initialized.
Apr 15, 2014 | Kyocera FS-1118MFP Laser Printer
Resettare errore c6
1-4-1 Maintenance mode
The machine is equipped with a maintenance function which can be used to maintain and service the machine.
(1) Executing a maintenance item
The selected maintenance item is run.
Press the back key.
Start
End
The maintenance item is
selected.
Maintenance mode is exited.
Repeat the same
maintenance item?
Run another maintenance
item?
Turning power switch off and back on
No
No
Yes
Yes
number using the up/down keys.
Press the system menu/counter key.
* The test print mode cannot be stopped until the preset number of sheets is printed. To stop the operation, remove the
cassette to cause a paper empty state. To terminate the test print mode in the middle of operation, you must turn off the
power switch and then on again to exit the maintenanc
when in maintenance mode go to 163 to reset
Mar 16, 2014 | Kyocera FS-1118 Printer
Kyocera taskalfa 300ci
10871087 to enter service mode. There are 2 maint. kits for the 300ci. One for color and one for mono. If you were able to perform a maintenance then you should be well versed on which adjustments to make and which counters to reset. If not you can cause major problems so be careful.
Dec 16, 2013 | Kyocera Office Equipment & Supplies
Service mode of kyocera fs-1120mfp
for kyocera 1820LA look if it's works:
turn on your computer by opening the top door previously.
you press the menu system.
you fit in service configuration and enter.
press the START and # then enter.
done this in configuration service runs a new submenu called maintenance mode.
until it happens you should try this.
when you enter maintenance mode out and then back.
browser to locate yourself U163 code.
you give execute.
Nov 13, 2013 | Kyocera Office Equipment & Supplies
Kyocera 1018 me sale error c6400
Zero-crossing signal problem
• The engine board (KP-5238) does not
detect the zero-crossing signal for the
time specified below.
At power-on: 3 s
Others: 5 s
Usually something wrong with electricity..
Try to clear this error:
Enter maintenance mode:
1. Press the system menu/counter key.
2. Select "Service setting" using
3. While pressing the start key and the # key,
4. Select "Maintenance mode" using
5. Press the enter key.
6. Enter the maintenance item
You need maintenance item 163
1. Press the enter key. A selection item appears.
2. Select "Execute" using the up/down cursor keys.
3. Press the enter key. The fixing problem data is initialized.
May 20, 2011 | Kyocera Mita LaserPrinter FS-1018MFP...
Stuck in the C6400 Error and cannot get out of it, nor print anything. My printer is a KYOCERA KM-1820. Any assistance would be appreciated.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Method
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note: Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 31, 2011 | Kyocera Copystar CS-1820 Black and White...
The code appears c 610
Hi ;
you should enter the maintenance mode and clear all memory :
to enter Maintenance mode type :
1087 1087
and type : 20 and prss start botton
Oct 19, 2010 | Kyocera KM-1510 Copier
Kyocera FS-2020D Laser Printer Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
