Question about Cell Phones
Charge complete chargecomplete on screen. phone makes & receives calls. charger not plugged in. beeps & displays charge complete. hit end buttom screen goes to normal, But battery icon flashes.tried different battery thats good same result. this started after it got wet.
    New Friend:
  • 4 Answers
I had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm thanks........
Posted on May 02, 2013
pingping
  • 111 Answers
SOURCE: Everything works but no display
Ah! My friend. you are lucky that you ask the right person. I have fixed so many V551 with LCD defect so this symtom is usual on v551 and most Motorola Flip phones. As you know, the construction of the LCD cable has been designed by a long ellectric thin wire and one side will connect into the main and CallerID smaller LCD and the other end will connect to the main board and the part in the middle will stuck inside the hinge where the flip will apply a lot of force for the function of open and close. for a long period of usage, it will either worn out the middle part of the cable or loose the connection of either side which cause loosing display. That is why you can call and receive but cannot see anything. The simple thing is open the case and check first at the main board side for any bad contact and tougher the other side is inside the main LCD. If you find both side are still good in connection then the middle part is bad due to flipping so many time of the user in order to open and close. YOU THEN NEED TO REPLACE THE NEW LCD. I have two solutions to help you in this case: 1) View on the link below for the instruction of how to open the housing. http://sbarth.dyndns.org/seiten/rahmen.php?nav=motorolahandy Sorry the link is in German but you can look at the picture to follow. 2) Or email me at joe_dao2003@yahoo.com if you want me to repair the phone for you. I will charge you for only $10.00 for labor fee and $5.00 for shipping. I am sure to make your phne back to normal or your money back. My shipping address is below: JOSEPH DAO P.O. BOX 390307 MOUNTAIN VIEW, CA 94039 USA If you want other way to help, let me know. I am sure you will be happy with your phone back to normal. I hope this help
Posted on Apr 11, 2007
pingping
  • 111 Answers
SOURCE: Razr V3i charging problem
Hi V3 is very fragile and if you use the incompatible accessories, you can ruin their ports easily. One weak point of V3 Phone is the SIM card Port is not an opening flap like other GSM phone but using pin and spring Port style which is mean you have to push your SIM card in and use the SIM Card edge to push the pin down in order to contact with SIM metal area interface. But by pushing force is varied from users so too strong and too hurry will damage the pin. If one of the pins is damaged, when you slide the SIM card in, the contact is missing of one or two pins due to damaging of the pin cause the error message "Insert SIM". In this case, only way is needed to replace the SIM Board underneath. If you can do it yourself, please follow the instruction pictures below. If you are not sure and never do this before, I suggest you send the unit to Motorola Repair Center. Your SIM Card Board and charging port will need to be replaced. http://www.itsjustmerob.com/files/V3_Razr-repair.pdf This is a Full Motorola V3 Officially Service Manual and even the Motorola Repair Center also has this one. so copy this link and print it out. Around hundreds plus pages but can be your Guide which you cannot find anywhere else. I gave it to you free but I have purchased it before. Hope that you can get it fix. Other solution is looking V3 parts on sale a lot on Ebay and use them to replace part to your phone will be cheaper if your phone is no longer under warranty. If it is still under cover then send the unit to them and don't spend time and money to do it yourself. But if it is out of warranty and want to avoid costly repair then use the method in the manual I provided you and you will be able to get your phone fix. Good Luck
Posted on May 15, 2007
  • 67 Answers
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
Posted on Dec 21, 2007
ahlrub
  • 283 Answers
SOURCE: V3 not charging
it's a hardware failure,, cant fix it here ..
Posted on Apr 16, 2008
SOURCE: my phone displays 'unable to charge' or no battery icon?
I plugged my phone up and all of a sudden got the message "Unable to charge" on it. I changed chargers (i had an extra one), i changed batteries (i had an extra one), and i swapped every combination imaginable.
My solution....
My Razr's plug has an opening to plug the phone that resembles a person's navel, and it got dirt and dust bunnies in it while it was in and out of my pockets. I was able to take an old tooth brush (or your new one if your really desperate), and got a can of office duster that you use to clean keyboards. Turn the can of office duster upside down for a second while you are spraying it and liquid will come out as you are spraying the connector. Immediately after that, use your toothbrush to work it inside the dirty connector to free it from anything that will keep it from making good contact. Then, hold the can of office duster upright and it will only spray air... and blow the connector free of anything that you loosened with the brush. Repeat this process if after all this it still doesn't work... because you have a REALLY REALLY dirty connector if it doesn't work after the first try.
Posted on Nov 17, 2008
Pantech ease battery
try a different battery and make sure the display indicates its charging
Oct 27, 2011 | Pantech P2020 Ease Crystal Screen...
The screen on my phone went completely black and will no longer turn on from what iv tried i cant hear or seen anything and there is no sighn of water damage what do i do?
I will try and keep this short. I have a Motorola Razr (puchased in the USA..... this will make sense later) and I lend it to my brother when he visits me from Canada. (Roaming charges for Canadians using their phone in the US is insane) He too has a Motarola phone that he brought with him. The Charger that he brought with him was for a Canadian phone. Apparently, you cannot use a charge for a Canadian phone, on a USA contracted phone..... I'm not sure why, but it is the case. He attempted to charge my USA phone with his Canadian Charger and the screen went blank. The phone was still on and could even receive calls. Even when the calls came in, the screen still remained blank. I won't bore you with any more details.
Here is how I fixed it:
- Unplug phone from Canadian Charger
- Take the battery out of the phone.
- Plug in USA built charger (without the battery in the phone)
- The phone attempt to charge
- Screen should turn on. Wait till screen indicates (Cannot charge battery)
- Plug battery in.
- Hold down power button to turn on the phone.
- Phone should be in working order.
I don't claim to be an expert. This may only apply to my particular situation. Hope it helps if you happen to use the incorrect charger. Take care.
Mar 22, 2011 | Motorola Mobility RAZR V3
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
LG Phone only on when charger is plugged in.
sounds like you have a bad battery. I would call accessory warranty exchange and have them send you a new one. just call your service provider and get them to transfer you to the warranty department
Aug 24, 2009 | Cell Phones
No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Aug 19, 2009 | Nokia Cell Phones
Phone keeps dropping calls
Same issue here. Have you checked the battery? I found out that on mine the battery was leaking and corroding the contacts. Need to call Panasonic to find out if they can do something (about 5 month old phone)
Apr 02, 2009 | Panasonic KX-TG9333T Trio Cordless Phone
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
SHARCNET-USA
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Charging
It's beeping because the battery is completely dead and needs to charge. If beeping doesn't stop after a while of charging, you may need a new battery or a new charger.
Jul 21, 2008 | Motorola Mobility RAZR V3
I can't even get it to come on
Press and hold the END to turn your phone on.
Once your phone is On, it displays "Looking for Service" which indicates that your phone is searching for a signal. When your phone finds a signal, it automatically enters standby mode – the phone’s idle state. At this point, you are ready to begin making and receiving calls.
To turn your phone off: Press END for two or more seconds until you see the powering down animation on the display screen.
Jan 18, 2008 | Samsung SCH-u740 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
