Question about Toshiba Satellite P750BT4G22 Notebook
My laptop battery sometimes gets so hot when I'm charging it that my pc shuts down
Hi. I'm using a toshiba satellite p750-bt4g22 laptop. I've had it for about a year and a half. Sometimes when I'm charging it, the battery gets so hot that it stops charging and shuts down immediately. I'm always using the eco feature and this has never happened when I'm playing games or when I was using Windows 7. This started when I upgraded to windows 8. Does it have to do with windows 8.
It might be to do with Windows 8, but what would be overheating is your processor or RAM. If it is the battery, Windows 8 might be too much drain, or it's simply coincidence and your battery is had it.
Posted on May 02, 2013
Testimonial: "Sometimes it still gets so hot that it stops charging even if the laptop is off. What could be the problem in this case?"
EricDaniels
  • 80 Answers
SOURCE: Shut down of laptop after blue screen appears
When you hit F12 or whatever F key to go to the boot drive menu, make sure the cd is in and that you select CD/DVD Drive and the dvd should prompt you to hit any key or will automatically start loading for the recovery. Just tell me if you need further assistance.
Posted on Feb 01, 2009
rockitman187
  • 2559 Answers
SOURCE: toshiba satellite P15-S420 odd power & freezing problems
  1. Click Start and then Control Panel.
  2. If you're in Category view, click Performance and Maintenance.
  3. Then click on Power Options.
    If you're in Classic view, double-click on Power Options.
  4. Click the Hibernate tab.
  5. The Enable Hibernation box should be unchecked.
  6. Click Apply.
  7. Click the Power Schemes tab.
  8. In the Plugged in column, from System Standby option, set a time out period.
  9. Click Apply.
  10. You can adjust the Turn off monitor and Turn off hard disks settings as well.
  11. Click Apply. Click OK. Close the control panel.
This is what you should see
Please rate this a fixya
Posted on Feb 09, 2009
RPFinney
  • 385 Answers
SOURCE: Toshiba Satellite A205 unable to fully shut down
possible setting issue.
If you Go to,
start, control panel, power options, (classic view)
have a look in the power options there, set as needed. there is a few, check them all out.
use disc cleanup,defragmenter, delete temp internet files, in tools on menu bar , delete history,
update the Operating system at Microsoft.
update virus protection and run a full scan.
you should be good if no hardware problems.
Regards.
Posted on Apr 16, 2009
  • 1768 Answers
SOURCE: Toshiba Satellite P30 (new) Battery (and old) not charging
1. You will need to check the power adapter it may have lost it's ability to send a charge to the board.
2. Also the connector to the PC may be damaged and the solder joint at the mother board may have cracked or damaged.
3. Check also that you have the battery completely snapped in place.
4. check the contacts on the battery itself.
5. You PC may need service.
Posted on Mar 27, 2010
n5kb
  • 349 Answers
SOURCE: WEBCAM DRIVER OPEN FAIL. Toshiba M300 satellite
Go here and download the driver utility for your webcam.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2228766&rpn=PSMD8U&modelFilter=M300-ST3402&selCategory=3&selFamily=1073768663
Posted on May 02, 2010
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
WHATS HAPPEN MY TOSHIBA SATELLITE A300-14S LAPTOP BATTERY NOT CHARGING THEN WHEN I REMOVE BATTERY PLUG DIRECT DC IF HOT AUTOMATIC SHUT DOWN
the laptop cannot ventilate the hot air out.may be a lot of dust covered the cpu fan.go to any service centre and get it cleaned.if you can do it yourself then its fine.it is becoming too hot and is shutting down.
Apr 05, 2012 | Toshiba Computers & Internet
My fan doesnt seem to be working and laptop just shuts down after it gets hot
Hi, your laptop shuts down as a protection against overheating. It's important that you take the laptop right away to a service repair shop so it can get the fan replaced before other important components get damaged.
Jul 27, 2011 | Toshiba Satellite L455DS5976
My battery charges but only lasts about 20 minutes once it says it is fully charged. Just purchsed a new battery thinking it was old (laptop is about 3 years old) and the same thing happens.
From what you describe and assuming the new battery was "new", I'd say you have an internal short which is draining the battery over a short period of time. I'd also investigate the accuracy of the battery charge indicator. Download this free utility which will give you a more accurate picture of your battery:
http://www.mioplanet.com/products/batterymeter/
I'm assuming you gave the battery a "commissioning charge" when you bought and used it?
If not, this is something you should do with all new LI batteries. This bit is reproduced from a website that sells batteries for the Toshiba satellite series:
"2. The new Toshiba Satellite a205-s4777 battery pack needs to be circled (fully discharged and recharged) three to five times to reach its optimum performance.
3. Toshiba Satellite a205-s4777 battery will undergo self-discharging when left unused for a long period of time. Thus, it should always be stored in a fully charged state and kept in a cool, dry and clean place.
4. It is normal if the new Toshiba Satellite a205-s4777 battery gets warm when being charged or used. However, please pay special attention if the battery pack becomes excessively hot. This may indicate there is a problem with the charging circuit of the electronic device. Please consult a qualified technician if necessary.
5. To maintain the optimum performance of Toshiba Satellite a205-s4777 battery pack, it is highly recommended to circle (fully discharging and recharging) it at least once a month.
6. New batteries are hard to be charged. Sometimes, your electronic device may indicate a fully charged condition about 10 to 15 minutes when Toshiba Satellite a205-s4777 battery pack is being charged for the first time. When this happens, remove the battery pack and let it cool down for about 10 to 15 minutes then repeat the charging procedure. Sometimes, the new Satellite a205-s4777 battery will suddenly refuse to be charged. If this happens, a suggested solution is trying to remove the battery from the device and insert it again. "
Jul 21, 2011 | Toshiba Satellite A205-S4777 Notebook
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
Toshiba Satellite a205 the battery light started
I think you may need a new power supply, check this to make sure it is working OK, If this isn't working then the battery will not charge, and give symptoms you describe.
Feb 20, 2010 | Toshiba Satellite A105 Notebook
If you Go to,
Regards.
Apr 16, 2009 | Toshiba Satellite A205-S4639 Notebook
Toshiba Satellite P750BT4G22 Notebook Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
