Question about RIM BlackBerry 7100G Smartphone
Blackberry 7100g Hi i have a blackberry 7100g and it is making a clicking noise when i dial and receive calls. It does not make it on every call but just about every one. You can barely here over the noise. Please just email me
  • C.D. Perry
    C.D. Perry May 11, 2010
    This could be caused by many different issues....
    Are you "roaming" on different company networks? Say T-Mobile to AT&T??
    My personal guess would be that the unit was dropped.... I believe I experienced this with a customer once, and then i later found out their daughter dropped in in a puddle.. lol
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service center and have them diagnosed the phone and see if it cna be fixed
Posted on Sep 14, 2008
SOURCE:
Hi can som1 tell me the mep code for my blackberry 7100g ime # 354594.00.083620.9 WITHOUT COST
Hello
You can get unlock code for your Blackberry online at cheapest rate, legal and 100% guaranteed unlock code by Blackberry unlock code provider. i hope this will help you.
Their IMEI unlock codes are 100% accurate and backed by Their money back guarantee.
Nov 21, 2010 | RIM BlackBerry 7100G Smartphone
Hi can som1 tell me the mepcode for my blackberry 7100g ime # 354594.00.083620.9
It is very easy to unlock Blackberry cell phone.You can unlock
your Blackberry by follow simple instruction.Contact your carrier
provider for free unlock code.otherwise no one give you free.you
can get MEP code for your Blackberry at cheapest rate by MEP
unlock code provider .after unlocking you will be able to use any
GSM Sim.
How unlock, blackberry 7100g
Hello.
You can unlock your Blackberry just enter unlock code through keypad and use your Blackberry with all GSM carrier provider around the world.Blackberry 7100g Unlock code provider.
Jun 12, 2010 | RIM BlackBerry 7100G Smartphone
I cannot hear or be heard when I make a call with my Blackberry
go on to your settings reset your phone you can reset it it'll just turn off your phone give it a little refresh and turn back on or you can master refresh which will turn off your phone give it a really good refresh it'll turn back on but if you master reset it will delete all our games music and stuff but im not sure about inbox emails & contacts but its up to you but if i was you i would choose master reset especially if it a new phone... so goodluck:) and please rate this solution thanks cya...
Jun 06, 2010 | RIM BlackBerry 7100G Smartphone
No one can hear me from my blackberry curve 8830
have you tried doing a soft reset to the phone by removing the battery leaving the battery out for 1-2 min and reinserting and then try making a call
Nov 18, 2009 | RIM BlackBerry 7100G Smartphone
My callers can't hear me.....
Replace the microphone.....you will need to take the phone to a mobile service center and ahve that done
Aug 23, 2008 | RIM BlackBerry 7100G Smartphone
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
People cant hear me when i call out
what you should do is take the phone and have the microphone replaced.
GUEST - replace the microphone
Jun 06, 2008 | RIM BlackBerry 7100G Smartphone
BlackBerry 7100G HELP
i see u have quite a few people having trouble with making phone calls and the person on the other line cant hear them however the caller can hear them perfectly well
well... i have the same problem!!!
ur answer was to buy a bluetooth ear piece??, correct?
good idea!
but, buying a phone to make calls and it doesnt even do its main function (calling out) is very frustrating.
I mean isnt the whole point of a phone, is for one to hear you on the other line?
please help me my phone is getting to my last nerve
please please
is it a technical problem?
Jun 03, 2008 | RIM BlackBerry 7100G Smartphone
When people try yo call me I can heard them they can't
Try using your headset that came with the device.... do you have the same issue? If not, there is a problem with the ear speaker...
Hope that helps... :)
Mar 08, 2007 | RIM BlackBerry 7100G Smartphone
RIM BlackBerry 7100G Smartphone Logo
67 people viewed this question
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
