Question about Zanussi Washing Machines
Replace pump how to remove/replace drain pump on zanussi zwg 1140M
  • Zanussi Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on May 02, 2013
  • 1462 Answers
SOURCE: Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
Posted on Jun 29, 2008
SOURCE: Drain pump FJ 1454W
Prob sorted, phoned Zanussi service enginneer
Posted on Nov 13, 2008
  • 135 Answers
SOURCE: Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Posted on Nov 26, 2008
  • 47 Answers
SOURCE: I am looking for a downloadable instruction manual
I WISH I KNEW HOW I COULD HELP YOU, BUT I DON'T KNOW WHERE YOU CAN FIND A MANUAL FOR YOUR WASHING MACHINE AT. IS IT NEW?
RODNEY
Posted on May 15, 2009
techbuster
  • 5081 Answers
SOURCE: Zanussi Aquacycle 1200 Model F1245W wont drain.
We cannot say if the timer is problem without inspecting the wiring to the pump.
Consider an power supply wire to the pump is broken , then even if the timer is good it wont get power.
Posted on Sep 06, 2010
Turns on. Fills with water, then why does it display error code e60?
Someone posted a list of codes: Error code e60 zwg 1140m
Some people say they just pressed and held the reset button for 5 seconds.
Nov 26, 2015 | Zanussi ZWF1430W Front Load Washer
Hi my Zanussi ZWG 1120M washing machine has stopped spinning, no error code is displayed, what could this be?
First check if the water remaining in the drum?
If it is, then the fault is in the drain phase (drain pump,filter...etc.) before the spining cycle.
Otherwise, faulty is motor, belt, electronic....etc.
By the way, model is unknown to me.
Dado
Jan 11, 2015 | Zanussi Washing Machines
Heating time out. Could be heating element.
Dado
Sep 12, 2014 | Zanussi Washing Machines
How to fix a heater zwg 7120p
You will have to purchase the heating element which for your model might look something like the one shown on this site.
Washing Machine Heating Element with Sensor
The instructions to replace this should come with it.
If not then try to download instructions from here which is usually similar for most European front loaders like yours.
How to replace washing machine element front mounted in Bosch washer
Sep 02, 2014 | Zanussi Washing Machines
User manual for zanussi washing machine ZWG 7160 P
how do i replace washing machine drain hose on zanussi zwg 7160p
Jan 16, 2012 | Zanussi Washing Machines
Hi i need a manual in english for zanussi 1140m am in denmark but only read and speak engish
Hi!!
Try the following link to download your manual. http://www.nodevice.com/user_manual/zanussi/washing_machine5/w1042w.html
Scroll down, enter the code on the box and click DOWNLOAD
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 16, 2011 | Zanussi W1042W Front Load Washer
Drain pump FJ 1454W
Nov 13, 2008 | Zanussi FJ1454W Front Load Washer
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
