Aiwa nsx k580
Not getting on only power led is glowing.
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
  • 6 Answers
SOURCE: aiwa nsx-9000 is eating my tapes
Well 1st unplug it then you can start by qtip cleaning, blowing internal maintenance service. But for the most part regardless of use or age whenever there is gears, bands moving parts which in time get worn, Now this is were keeping clean extends life, So time to shop for a new 1 because repairs and part availablity exceeds the value,of your problem
Posted on Mar 04, 2009
Grubhead
  • 5259 Answers
SOURCE: i have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
Posted on Feb 27, 2010
  • 7 Answers
SOURCE: aiwa nsx-999 display and cd changer problems
replace lazer ever 2000 hours the display may have a dry joint on the 18 volt input ps the lazers are all the same in all the nsx moduls
Posted on Mar 23, 2010
dunnbiker
  • 8546 Answers
SOURCE: It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Posted on Apr 30, 2011
Stand by problem
do have the the circuit book of aiwa nsx k880
Apr 08, 2014 | Aiwa Audio Players & Recorders
I have an aiwa nsx-vc58 system, it is now only glow standby light but no current in the display or cd, what can i do?
It is more than likely a problem with the audio output chip, the only solution is to have it replaced.
Apr 14, 2012 | Aiwa Audio Players & Recorders
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
What sub woofer should be used with my aiwa cx-nhma 86
Any self-powered subwoofer that accepts RCA Line Level input (most do).
http://www.retrevo.com/support/Aiwa-NSX-HMA86-manual/id/1076ag421/t/2/
Page 28.
Apr 17, 2011 | Aiwa NSX-HMA86 Shelf System
My Aiwa NSX 990 wont come on. Only timer icon come in display and volumew LED keeps coming on and going off at regular intervals
Unplug the power cable completely to turn off and then turn back on again. Check whether there are no lose parts with missing contact.
Most probably it looks like a deeply digital problem with no do it yourself solutions - bring it to the repairman, but I even doubt he would fix it.
You can also download the Aiwa NSX-990 service manual and analyze more specifically your case. Download it from here: http://www.mediafire.com/?jc0ynzoiama or from here: http://www.4shared.com/document/rQ67hcpG/Aiwa_XG-990-NSX-990-NSX-992.html (click "Download Now", not any other button).
Dec 06, 2010 | Aiwa AV-S17 Receiver
Need programming code for Aiwa NSX-MT920
Your Comcast universal remote control may not contain the code for your Aiwa system. All universal remote controls do not contain all possible codes.
Nov 24, 2017 | Aiwa NSX-MT920 System
AIWA NSX-2700 Alarm
On the remote hold shift and press timer button.
It should go off.
Hope this works for you
Kurt
Dec 27, 2008 | Aiwa NSX-2700 Shelf System
24 people viewed this question
 Grubhead
Grubhead
