How to fix error code E002 on canon NP6028
Error code E002 apear when start up a machine and after few second machine switch off it self
SOURCE: Canon PC-850 E002 Error Code
I fixed it by putting it in service mode. (paperclip straightened to act as a pin pushing the reset button behind the front cover and simultaneously holding down lid release spring on the left with a pen). It reset itself and no more error code.
Posted on Jun 04, 2008
Cogz
  • 1326 Answers
SOURCE: Error code: E002 at canon NP6551
techbill is on the right track, but I would say just breaking the contacts on the the DC control may help- that is a good fix for older copiers. How may copies are on the copier? Have you had the copier moved resently? Or have you had some eletric work doe and is the copier on the same power circut with another device (AC unit) ? Also, can the code be reset in service mode, with no new parts put in? I have had the same problem on this mode and other models.... You said the tech replaced something with wires on it... Was it the thirmister? This model has two of them one towards the back of the UFR and one in the middle.. You also, may have a bad front door switch ( AC).... Asks a few questions.....
  • 47 Answers
SOURCE: error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
Posted on Jun 10, 2008
  • 16 Answers
SOURCE: a canon np 7161 with an e002 error code. It is my
ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, kibokoyao waiting for your vote.
Posted on May 14, 2009
  • 59 Answers
SOURCE: code error E002
hi 1. cheq the fuser heater lamp & thermal fuse,
2. enter in the sim mod by pressing service swich located in side the front cove you can see the $ sing at the screen left upper corner then press *4* then scroll to find the error then ok macine will re start and hope your error will go
thanks
Posted on May 15, 2010
Sir you tell me how can I reset canon ir 2002n error code e002-0000
Hello . to clear that error you need to replace the fixing heater unit
Apr 25, 2016 | Canon Office Equipment & Supplies
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
Hi there
On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format.
The page is here and carries all the error codes
Error Codes Canon iR2520
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
A canon np 7161 with an e002 error code. It is my
Apr 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
canon gp 405 copier their was problem E001 & E002 ?
I cannot find the problem
Jun 02, 2008 | Canon NP 6551 Black and White Copier
Canon NP-6035 persistent E002
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Jan 25, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
