Question about Hoover Washing Machines
Hoover hnt 6414
Will not spin
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: HNT 2135 Top Load Washer drum locked and can't
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
  • 6277 Answers
SOURCE: I have rented a furnished flat and i dont know how
Methinks you could do with a manual- for now and later!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Oct 14, 2011
I have rented a furnished flat and i dont know how to work with Hoover Nextra HNT 2135 Top Load Washer
Manual
John C.
Oct 14, 2011 | Hoover Nextra HNT 2135 Top Load Washer
I have a Hoover Top Loader HNT2135. The problem is that it will not spin. Makes a noise as though it is going to spin but doesn't manage to.
Hi.
If it does make noise and does not spin it is usually the drain pump clogged. Disconnect power, reach the drain pump and check for blockage in there . If that is not the problem check in order drain hose at the back, lid switch, pressure switch, and finally pump and motor from underneath the washer. The switches and motors can be tested using a multimeter.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 13, 2011 | Hoover Nextra HNT 2135 Top Load Washer
HI We have a Hoover 700LD washing machine that wont fill or wash. Will drain and spin. Any ideas? thanks
Thanks for choosing FixYa and welcome. You need to check your water inlet valve and make sure it is not defective. Check your water pump and make sure it is working right. The pump pumps the water into the washer.
Feb 05, 2011 | Hoover Nextra HNT 2135 Top Load Washer
Hello, my Hoover 700LB toploader won,t spin or agitate, the pump is working, but the motor is not working at all,
Hi just read your posting.Now the problem could be your motor or motor module.Have you got or can borrow an electrical test meter to test the motor and wiring? Please reply back and and I can guide you the finding of the fault and the repair.Also I will look at my manual to see if you can test for the fault without a test meter.Looking forward to your reply.
Aug 24, 2010 | Hoover Nextra HNT 2135 Top Load Washer
Spin Dryer doesn't work on Hoover 500M
Most probably the solonoid (also called brake motor). This is a 5 rpm motor that activates the drum to spin. I just replaced it two days back in my machine (Model 500M0AUS - you'll have to be specific when ordering or better take the old one to the spare part shop) which had a similar problem. The new soloniod I bought had a shorter cable length so I had to improvised when fitting. If soloniod is the problem then make wure the steel brake lever tooth fits perfectly in axle groove when you finish replaceing it. Do the replacement when the machine has fully stopped after completing its wash cycle.
Repair technician quoted 250 while the solonid costed me only 86. I did not charge labour to myself:)
Hope this is helpful.
May 28, 2009 | Hoover Nextra HNT 2135 Top Load Washer
Hoover 500M Top Load washer - Water overflow & machine wont wash
Probably very repairable but impossible to say how much without looking inside and fiddling around and checking a few things.
Fault could be caused by several possible faults at widely varying cost.
I suggest you call a friendly local white appliance engineer...
Feb 13, 2018 | Hoover Nextra HNT 2135 Top Load Washer
Hoover 500m spin cycle
That sounds like a broken motor couplin, slack drive belt, or worn bearings.
A repair person can determine which is it. I cant tell from here. However,
If you do this test you can eliminate one of the above. Lift the lid of the washer, hold the rim of the inner-tub and spin it clockwise and then anti-clockwise. If it spins both ways, you have a bad bearing which needs replacing.
May 31, 2008 | Hoover Nextra HNT 2135 Top Load Washer
Hoover washing machine (commodore 5.0 kg)
this is either a belt slip or a squeeling bearing ater seal, if it is not the belt then try doing a boil wash, this often resolves the problem. Regards Advisor
Jan 30, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
