Question about Samsung ASSY LABEL-CIRCUIT DI - DA99-01457B
Da99 00258a there is a smell coming from the fridge/freezer like hot plastic
Chemical smell
hot plastic. the motor bearings are bad
Jan 01, 2014 | Shop Vac Vacuums
Led light wont come on
When you remounted the freezer door you might have missed or damaged the switch (button) when you moved the unit. Check that and replace it if necessary. That should fix the problem.
Nov 14, 2013 | Electrolux Vacuums
I purchased a vintage Pyrex lemonade pitcher with a plastic lid on eBay. It was packed in shredded newspaper. Though clean and well cared for, the lid stinks of a rubbery smell. I'm concerned about...
1) dismantle the plastic lid into its various parts and put them in a bowl.
2) into the bowl, pour 1/2 cup of white vinegar
3) add 1 tbsp of baking soda
4) lastly, pour 2 cups of hot water (not boiling), enough to cover the plastic lid. Stir to mix the solution thoroughly.
5) leave to soak for 2 days
Sep 11, 2011 | Vacuums
Smell of rubber or plastic burning when in use.
Does your unit have a power nozzle?-- could a belt be slipping at the floor nozzle?
When does the smell begin-- Immediately-- or after running awhile?
Do you feel anything in the power cord that is HOT?-- or the wall plug?
(You are not using an extension cord, right?)
Tell us more about the machine, and when and where you notice the smell the most--
Mack B
Dec 28, 2010 | Vacuums
Smells like burning
We had this same issue. I noticed it smells like burning plastic. I took it apart and did not find any fundamental problems. Ball bearings on motor are fine, no play. What I did find was that the motor construction contains lots of plastic. It's made in China. Even the brush holder is plastic. Now, this is unusual to me, as brushes get very hot. However, I did not find any issues of melted or softening plastic when running. I used a laser-guided thermometer and measured about 170 degrees F on the metal portion of the brush holder. Nothing unusual. Some parts reached above 200 degrees F. Again, nothing unusual. The only unusual issue is that many of the parts are mated with plastic parts. That's where I believe the problem lies. When the motor is new, the brushes don't make full contact. Therefore, full power draw is not achieve until these brushes wear down a bit. After this point, the brushes reach maximum power delivery and reach maximum temperatures. This is why I believe the vacuum didn't exibit any smell until a few months later, at least, for us. In conclusion, I didn't find anything wrong, except that the motor is cheaply constructed. It isn't going bad and well likely last quite a while, IMHO.
MAJ
May 01, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Whenever i turn on my rainbow, it smells like dirty feet. i have cleaned the canitster, but it still smells and its coming from what looks like the plastic filter maybe?
there is a hepa filter on the back of unit, if you remove and than run the machine you can find out if that is where it is coming from. Most likely is.
Oct 17, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Burning smell and not picking up
check for blockabe in bag inlet area, or bottom of unit by intake pivot.
ez check is to feel if bag blows firmly up with air when on, if not, you have a blockage.
Nov 02, 2008 | Oreck XL21 Bagged Upright Vacuum
Power Consumption Refridgerators
I have a 10KW stik welder/generator. I have no problem running a large freezer and 2 fridges except for the startup current draw. I have a $300 transfer switch connected to a 60amp sub panel with current meters on each leg. I have to watch the current draw and turn on & off breakers. I do have to play the "green acres" game because I have the water heater, well pump, and kit ckt all connected as well. Coffee machine, toaster, oil furnace, microwave all have to take turns as well as the water heater(4500WATTS). Cost was about$3500 in 2001 and $600 for a generator shed. lots of my labor. Last time we lost power it payed for itself. 28 hours without a generator would have been a trip to a hotel and lots of spoiled food to dump. hot shower and coffee anytime a big +
Nov 20, 2007 | Vacuums
Samsung ASSY LABEL-CIRCUIT DI - DA99-01457B Logo
23 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
