Question about Sony V SERIES BRAVIA KLV32V300 32 in. LCD TV
SONY BRAVIA KLV32 BX320 POWER REGULATOR BOARD AND MAIN BOARD
POWER REGULATOR AND MAIN BOARD AVAILABILITY AND PRICE
  • 150 Answers
SOURCE: I have a 4 month old sony bravia 1080 120mhz Sony
Not common but electronics are electronics , we can have failures right out of the box. Generally Sony is reliable and I must say that you should not have to worry about cost , Is it not under warranty - its only 4 months old !!
Posted on May 13, 2009
  • 257 Answers
SOURCE: Sony Bravia V series is on standby. Does not turn on.
That is true. You need to change a new board as when the chip is blown, all the related SMT cap, resistors, and transistor were gone, too. Those tiny component are hard to repalce one by one. Importantly, some of them was changed value and it only happens when the TV is warm up.
Posted on Aug 18, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: sony bravia kdl40S504 has green ghosts - cannot
I do not think that cause by power surge, and it is on manufactory warranty, you better to call Sony.
Posted on Jun 26, 2010
SOURCE: SONY BRAVIA KDL-26U2000 / Electronic Board broken
Try to unplag the power cable for 15min.
Posted on Jan 10, 2011
smarthome2
  • 1114 Answers
SOURCE: I have sony bravia model: KDL-46v4100 has problem
Try www.shopjimmy.com or www.retechtv.com Hope this helps
Posted on Jan 13, 2011
TV will not power on at all. Is there a fuse or circuit breaker readily available.Sony KDL 46W4100 7yrs old Flat Panel LCD
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Dec 24, 2015 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Sony bravia screen plz
Nov 20, 2015 | Sony Televison & Video
How can we fix our Sony Bravia TV
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 18, 2014 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony bravia cx32
Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 03, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
1year 2months old Sony Bravia KDL46HX820 powers on for few seconds ; I see black clouds on the top left corner ; TV switches off and 4 red lights blink ; Please advice on what might be the issue
No Vertical Sync is the fault. This is a main board fault. The main board might need replacement. But before confirming, check all the voltages comes to the main board from the power regulator board. If you wish to know more about the voltages and their sources, check this link.
Jan 30, 2013 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Sony Bravia KDL-37M4000 37 in. HDTV LCD TV will not turn on
Check its main power regulator section circuit. Replace the power regulator board if necessary. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Aug 18, 2012 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Dead
Hello George, hi it seem your TV is on standby mode, this happens when the power supply board detects a short, overload or any part on both main and power supply board gone bad. This needs to be checked properly by a highly skilled tech people. The problem could be the main board or the power supply board. we usually check first the main board, for any bad parts, like loose screws/wiring, bulging capacitors, overheating ICs, or water marks. If a OK, we then check the power supply board, well usually this is the culprit, bulging capacitors, or overheating regulator. or you could replace the entire power supply board. check for its availability online or on your dealer, ask also for service if the charge is reasonable.
Apr 30, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony V SERIES BRAVIA KLV32V300 32 in. LCD TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
