Question about Vizio E420VL 42 in. HD-Ready LCD TV
What screws needed for vizio stand mount model # E420VL 1080P 120HZ? M-5
I lost my screws that came with my 42' VIZIO stand mount. The Model is E420VL
    Top Expert:
  • Vizio Master
  • 74,198 Answers
Contact the authorized service center for Vizio.
Posted on May 02, 2013
SOURCE: Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Posted on Mar 18, 2010
  • 148 Answers
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
Posted on Feb 05, 2010
  • 6 Answers
SOURCE: Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
Posted on Mar 31, 2009
SOURCE: Missing screws for detachable stand
www.searspartsdirect.com ,base screws #4x26 tap part#172100042650 $2.16 there in stock
Posted on Nov 05, 2010
freetek
  • 5568 Answers
SOURCE: My vizio e420vl turned itself
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
Posted on May 29, 2011
Sometimes when i turn the tv on there is no volume. I need to turn it off and back on multiple times until it works
Main system control memory IC fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 25, 2016 | Vizio E420vl 42-inch Class Lcd Hdtv 120hz...
What size screws do i need for mounting a vizio 55" to a stand?
This depends on the model being hung on the stand. The size screw to use is usually listed in the manual. Also make sure to check the maximum length of the screw or you can damage the TV.
Dec 03, 2014 | Vizio Televison & Video
Tv will not come on. I have unplugged it waited 30 min an nothing.
those model have a common problem on the power supply
you can find one here :
http://www.bostonrecycling.net/lang/965-vizio-0500-0412-1220-power-supply-backlight-inverter.html
its plug and play, easy to do...
let me know if need more help
Oct 16, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
What size screws do I need to mount the VESA to the back of a 39" Vizio?
Most flat screens use 4, 6, or 8mm, be careful not to use too long a screw.
Aug 08, 2014 | Vizio 39" Class 1080p 60Hz LCD HDTV - Full...
Vizio e420vl screen whitish gray with black line, please help :(
mine did this I was told to pull out he plug and let it sit for about 20 minutes then plug it in. Hold the power button in for about 12 seconds to reset the television. worked good. oh keep your television away from AC s open windows. moisture can kill any electronics with just a few minutes of damp air.
Apr 21, 2014 | Vizio 42" E420VL 1080p 120Hz Widescreen...
Vizio E470VL - What is screw size for mounting stand?
I don't know if the screws would be different depending on the tv model, but on a Vizio Model E470VLE 47" LCD HDTV, the screws for the base are M4 x 30ST.
May 21, 2012 | Vizio Televison & Video
Missing screws for detachable stand for vizio e370 va
Try to contact (says your set is Vizio here) the company who made it...Also try to GOOGLE MODEL NUMBER OF SET WITH "MOUNTING BOLTS"
Mar 24, 2012 | Vizio E370VA 37 1080p 60Hz LCD HDTV
What size screws do you need to mount a 32" vizio lcd tv
according to manual the screw type is M6 , 1.00mm pitch and length is dependent on thickness of stand . you should have had a packet of assorted sizes of screw with the stand . you can also get the users guide by typing in make & model size
Jul 03, 2010 | Vizio L32 32 in. LCD HDTV
Vizio E420VL 42 in. HD-Ready LCD TV Logo
611 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
