WF1702WEC manual Machines stops washing and shows sud code ?
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: when you start to wash. The washer will flash a
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Nov 03, 2010
mc1bean
  • 3053 Answers
SOURCE: Whirlpool washer model #tw9500tw01 shows suds on
Hello, adrian
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Nov 01, 2011
  • 47 Answers
SOURCE: I have a Bush WV 1460TVE washing machines and I have a code showing ERR 5 and stops mid cycle. What does this mean?
This is from the manual...
Err5.... CAUSES/SOLUTIONS: Water level not met in 8 minutes/Make sure that tap is turned on and water pressure is normal.(a)
C/S:Height of the drain hose is below 80 cm/Install drain hose within80-100cm of height. (b)
C/S: The drain hose is in water/make sure the drain hose is not in water. (c)
Posted on Nov 04, 2012
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
I have showing 5d does not spin what does it mean
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Jan 04, 2015 | Kenmore Washing Machines
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
SUD AND F-35 PROBLEM
SUD= The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future
As far as F35. Check your owners manual to see if its in there. Also if you remove the top lid ( a couple screws in back hold it in place) and check inside you will get the technician diag sheet which will have codes.
Jul 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Water will not spin out. Code says 5d
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Frontloader shows SUD but no visible suds ....then machine stops working. also shows F34 numbers. Have tried resetting by un-plugging . then works fine for a few times then shows SUD again and we have to...
You may have a clogged drain filter.
Remove the bottom front panel to access the filter. Unscrew the filter,clean and replace the filter. Also,run 2-3 wash cycles with no detergent at all.
When using HE detergent,use the exact specified amount. With front load machines more is not better.
Nov 28, 2009 | Whirlpool Washing Machines
SD error code won't go away
Manual says -
"Sd" (Suds Detected)
directions.
Let me know if this helps, or you would like more information/help.
Feb 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag front load whasher MAH8700AWW Error/Information code OE is showing and does not show up in owners manual. What does this mean
my maytag mag8700 (4 yrs old) has begun to shake so bad itt walks 4" to the wall. it did not do this before. i regularly get SUDS code. i did run afresh through 3x's. 2 weeks later i have SUDS code again HEPL!
Mar 23, 2008 | Washing Machines
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
