Question about ZVOX ZBase 550 HSD
Zvox setup code
Do you know the comcast remote code to control the volume?
I need setup code for my zvox sound bar for a Comcast remote?
I am the same boat. Just bought a bigger tv and my zvox doesNOT work now
Jan 26, 2015 | ZVOX 4002201 Audio Z-Base 220 Low-Profile...
I lost my zvox remote, which universal remote will work best?
Check this link. You can get setup codes and setup proceedings to different brands of remote controls. Check it and find the appropriate one.
Feb 01, 2013 | Yamaha Televison & Video
I want to control my Sony DAV-HDX576WF with my Comcast remote control and need the remote control code.
Reposting from multiple sources.
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TVicon1.png/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951Power = 32719Mute = 33743
Good luck. Let me know if it works.
Also, to program your remote to function volume controls while in CBL or TV mode without switching between modes to change the volume, see below. Source http://www.hifi-remote.com/forums/viewtopic.php?t=8831Quote:Locking Volume Control To TV or AUX Mode:
1. Press and hold SETUP until the Red light flashes twice, then release SETUP.
2. Enter 9 - 9 - 3 (Red light will flash twice).
3. Press and release either TV or AUX (Red light for selected device will flash twice).
Jan 29, 2012 | Sony BRAVIA® DAV-HDX576WF Theater System...
Looking for remote codes for vizio sound bar and comcast remote
I have a vizio universal remote and the code that works the vizio sound bar is the first one listed under audio/vizio 0660
Oct 16, 2009 | Televison & Video
What is the 5 digit code for sylvania 26'' lcd tv
Go to comcast.com they have a remote link for codes
Dec 22, 2008 | Televison & Video
Samsung code for a comcast cable box
The Remote w/ On Demand buttons, it's the same as the DVD player code 1932. Hit the AUX button, press and hold SETUP until AUX blinks and enter 1932. Press the power button and it should turn off the reciever.
*UNLOCKING VOLUME CONTROL* You must until your AUX volume control in order to use your Comcast remote. To do so, you must select AUX, press and hold SETUP until AUX blinks. Enter 9-9-3 and press Vol - (down). This should unlock your volume control when you select AUX. I'm not sure how to set AUX as your default setting for volume, unless you were to program your AUX device as your TV and vice versa I'd suspect.
Hope this helps!
Sep 25, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
What remote control code does the Onkyo TX-SR304 use?
1) Tap AUX
2) Press & Hold Setup (1 then 2 blinks)
3) Enter 30842 or 0842 (The remote should blink twice)
4) Press & Hold Setup (1 then 2 blinks)
5) Enter 994 (2 blinks)
6) Tap Setup (1 blink)
7) Enter "00051" (1 blink per number)
8) Tap Power (not All On, just "power") (The remote should blink twice)
9) Tap AUX
10) Press & Hold Setup (1 then 2 blinks)
11) Enter 30135 or 0135
Aug 27, 2008 | Onkyo TX-SR304 Receiver
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Need setup codes for Akai KC01-B2 to run with comcast remote
I have an Akai 42"lct & had the same problem. I bought an universal remote URC R6 at walmart for $19. I can now control the tv, u-vrerse cable, panasonic surround system & still have the aux open. You must use the "learn" method but I can control channels, volume, record, menues for all devices as well as setup, record for dvr & more. I hope this helps.........
Jan 29, 2008 | Akai CF2791 27" TV
ZVOX ZBase 550 HSD Logo
73 people viewed this question
Top ZVOX Home Security Experts
Lawrence Oravetz
Are you a ZVOX Home Security Expert? Answer questions, earn points and help others
