My new lg wp610n washing machine washing spin cycle is just 3-4 sec.it is zoo brief that its not washing properly.im using it for the first time after it was bought ten yrs back.and it's timer wasn't working
    President:
  • Washing Mach... Master
  • 662 Answers
Http://www.managemylife.com/mmh/owner_manuals
Posted on May 02, 2013
onthejob5130
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
  • 3230 Answers
SOURCE: Replace Timer Assembly on GE WJRR1470E1WW Washing Machine
Servicing the Timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
In the next section, we will examine two of the most crucial elements of a washing machine -- the water inlet valves and the agitator.
Posted on May 17, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
  • 713 Answers
SOURCE: after the wash cycles the machine wont drain or
Hi just read your posting .Sorry to ask you this about your lights being on but I need to be sure.Now how many lights do you have in the row that the lights are lit?Is it 8 in total?Now starting from the far left please tell me if it is the 1st and 4th or 3rd and 6th and 8th etc.I just need to be 100% sure because my manual says it is the display module that is faulty and they are not cheap.Please reply and I am sure I can rectify this fault for you.
Posted on Jun 11, 2010
Testimonial: "This person is efficient and I'm so thankful for their help thus far!!"
Why would machine throw a PF error code in spin cycle?
The PF error code indicates "power failure" condition. The fact that it was indicating on the display while fully loaded tells me that you have a bad electrical connection somewhere on the machines PC boards or supply.
The spin cycle is also triggering this condition when the vibration on the machine shakes the "bad" connection and causes a brief loss of power to the machine.
Sep 19, 2015 | LG SteamWasher Series WM2650HWA
Washing machine will not engage drum in wash or spin mode
it sounded like the brushes have gone but you said you replaced them right? usually when the drum stops spinning its because the brushes have completely worn down and there is nothing left are you sure you snapped them into place properly or brought the correct model numbered ones? then are very difficult to get into the correct place I had a very similar problem and it took four attemps to get them in thr right place they are not the most easiest of things to do. if you have then it might be the motherboard electrical component if this is the case you will need a new machine im afraid if you dont have that much disposable funds try the freecycle website the offer free stuff look for you nearest area and take a look
Apr 15, 2014 | Bosch Washing Machines
My washer seems not to spin properly during the rinse cycle and will not spin now i get what i assume is an error message ue when its time for the spin cycle to begin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | LG WM2455 Front Load Washer
Can I run my LG front load washer on just spin cycle only to take some additional water out of laundry?
I don't think the technicians read this question properly. I too am wondering since there is no specific spin setting - in other words - no button to choose for JUST spinning - is there a way to get this machine to JUST spin? I have from time to time a load that is accidentally set on delicate and it does not spin properly. the clothes are clean and I don't want to go through another entire cycle just to spin them out. thanks for your help.
Nov 01, 2010 | LG Washing Machines
Code LE, will not finish the spin cycle
It's very important not only to use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect dosage instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Apr 01, 2010 | LG WM-2277HW Front Load Washer
LOUD!!! Spin cycle
Whats even more mundane ,this plays havoc on the electronics and specifically the expensive control board.Opt for extended warranty coverages!
Aug 15, 2009 | LG WM2455 Front Load Washer
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
LG 1285
Lg washers used to carry a 3 year warranty.check warranty as requires a new stator.
Jan 05, 2007 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
