Question about Ricoh Office Equipment & Supplies
Ricoh aficio sp 3400sf fault code sc 543 - Ricoh Office Equipment & Supplies
5 Suggested Answers
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: my printer ricoh aficio SP 3400SF is showing
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Posted on Jun 26, 2012
  • 13 Answers
SOURCE: service call sc:543 for Ricoh Aficio 1515mf
plz do like this after again it shwos same then need to replace parts thermister,and thermal fuses. press the yellow 107 red and hold the red for two mints it shows copy sp.......like switch off on
Posted on Sep 19, 2010
Joed911
  • 4338 Answers
SOURCE: Ricoh Aficio SP 4210N- Code
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Posted on Aug 18, 2011
Ricoh Aficio SP 3510DN sc 543
SC543 high temp error.
Reset fuser error. If it reoccurs could be a bad ECB(engine) or PSB(powersupply) board. To reset fuser error go to maint. mode
Hold stop/start & escape and turn power on. OK. look for reset fuser error.
Oct 03, 2017 | Ricoh Office Equipment & Supplies
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
How do i reset SC542 error in Ricoh Aficio SP300DN?
by one immediately.
Feb 23, 2015 | Ricoh Office Equipment & Supplies
Error sc 543
fuser assy replace or have tech fix will need to reset code if you replace fuser assy
May 15, 2013 | Ricoh Aficio SP C311N Color Laser Printer
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
by one immediately.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Service call sc:543 for Ricoh Aficio 1515mf
Mar 25, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Service mode
call service --- possible bad thermistor (fuser)
could over heat
Mar 17, 2009 | Ricoh Aficio SP C410DN Laser Printer
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
85 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
