Konica bizhub c220 copier c9401 error code - Office Equipment & Supplies
4 Suggested Answers
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
  • 51 Answers
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Posted on Aug 30, 2009
  • 158 Answers
SOURCE: Error code EA3226 when I try to scan to e mail on
this error code is not listed in any of the konica c220 books or on the konica minolta service tech internet site
Posted on Dec 04, 2009
Konica Minolta bizhub C220 error code C-D010
disable hard discor try to do physicall format in service mode
Feb 18, 2016 | Konica Minolta bizhub C220 Color C / M / Y...
Error code c9401 konica minolta bizhub 36
Scanner lamp assembly, that is the bright light that come on the document feeder, there is a problem with it. Need to be replaced. or the control board needs to be replaced. No reset
Sep 06, 2014 | Konica Minolta Office Equipment & Supplies
Imaging unit
konica minolta bizhub c654e in display error c9401
no Utility/Counter key. howcreset I resolve lamp already change
Oct 29, 2013 | Konica Minolta Bizhub C550
Fusing heater trouble konica c220
You need to change the thermistor on the fuser unit.
Sep 11, 2013 | Konica Minolta Bizhub C220 Color...
Konica minolta C252 error code C9401
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
Jan 30, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
My konika copier error code c9401. How to clear code.
Try this steps
adjustment.
1 Check the flat cable for proper connection and
2 Change PWB-C.
Please let me know if you have any further questions or concerns.
Thanks.
May 03, 2010 | Konica Minolta bizhub C250 All-In-One...
Error code EA3226 when I try to scan to e mail on Konica Bizhub C220
Nov 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
adjustment.
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 copier with a C9401 error code
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
Aug 02, 2009 | Konica Minolta bizhub C351 All-In-One...
91 people viewed this question
jasbo
jasbo
