Question about Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter
Flexsteel chair battery charger batteries - Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter
2 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: old chair battery charger 2904-24 automatic 3
Here is a link to 2 pages which stock parts for wheel chairs and power scooters.
http://www.monsterscooterparts.com/jet3ultra.html
http://www.southwestmedical.com/replacement-parts/pride-mobility/jet-3-ultra
Sorry couldnt get you the exact part number as i dont have the exact details of which unit you want it for. But most of the pride mobility range use the same battery charger.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Posted on Jul 10, 2011
Batteries replaced. Why can't I get it to charge?
Hi Judy, have you checked the wiring of the batteries , does the power chair work ? if not check how the batteries have been wired..
the charger cannot see the batteries , check the reset button and the fuse for the charger line ..
Regards
Rob
Oct 08, 2015 | Pride Jazzy Select Gt With 2 Batteries In...
What makes the on board charger not work an how cah it be tested to see if it is good.
There is a fuse in the charger and another in the chair for the charging circuit. Poor connections to the controller and at the batteries will do it too. If the batteries have been completely discharged, then the onboard charger does not have enough power to start recharging them. If that is the case, use an automotive 12 volt charger that has no automatic charging circuits in it to charge them individually. That means removing both batteries from the chair and connect the charger to one battery at a time. You can test the charger with the batteries disconnected and measuring the voltage on the wires you just took off the batteries. The voltage should be 28 volts or so if the charger is working.
Jun 29, 2015 | Jet 3 Ultra Power Chair
Battery charger is blinking
Most chargers have a certain color light that should be lit when the charger is charging the batteries. If this is what you normally have had, the blinking light means the batteries in the chair are dead or disconnected somehow or the charger is defective. If your chair is still turning on you may have a bad connection somewhere or the charger is defective. If the chair does not turn on anymore the batteries may be to dead to charge. Also if it does not turn on you could have a blown fuse or something disconnected in the battery wiring harness that will not let the charger work.
Oct 06, 2014 | Health & Beauty
Flexsteel electric recliner positioned itself in full reclined position and is now stuck there. Help!
It seems that you have a short in the chair control. You should be able to get a replacement from the manufacturer. They can be contacted at http://www.flexsteel.com/home-furniture/customer-service/contact-us
Sep 09, 2014 | Furniture
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
We have a pride jazzy 1143 select power chair. we have had problems with the batteries going bad. I purchased a new set of batteries last December. in June they would not hold a charge and I purchased a...
charger is no good or is not the correct charger for that chair suggestion have a dealer tech replace a original charger in chair,it should have a 3 yr warranty anyways
Oct 22, 2013 | Pride Jazzy 1103 Ultra Standard Power...
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
I bought an MPV5 used. Batteries won't charge. Charger light is green after 24 hours...slight power surge then dies. The seller said it hadn't been plugged in for a long time. I also noticed the batteries...
Lets solve this, one question at a time ....
First your batteries are not charging,This may be because of it siting for too long without a charge.The batteries may be so dead that your charger cannot reconize them. dont losse hope there are ways to check your batteries and charger with out spending alot of money on a tech coming over.
1) Unplug and remove your batteries from the chair
2) Find your self a charge that trickle charge
(Note: If you have a batterie charger ,trickle charge is the lowest set charge)
3) Trickle charge each batterie to about 50%
4) Install batteries back on to chair
5) Plug in chair charger
The chairs charger should come on ,and that right there tells you that you have a good charger!
The batteries that came with this chair are not bad and are considered ok to use .These type of batteries are what you call maintenance batteries ,which your always having to check if the leaking or need water.The gell type batteries are what they call non-maintenance.That you dont have to always look after but are more money.Thats why they recommend the gells so that the user doesn't have to work on there chair.
I hope that was helpful ,Happy Riding
Feb 10, 2011 | NRS Hoveround MPV 5 - Used Power...
Battery will not charge. No power indications when charger is pluged in.
If your charger light does not come on when you plug it into the wall, the charger may need to be replaced.
If the controller does not react at all after the charger has been connected for serveral hours, there may be a bad fuse. Even if the batteries are low, the controller should at least flicker on and off to indicate that is is trying to come on.
If the charger lights up when you plug it into the power chair, but the power chair does not respond when you turn it on while the charger is connected, or the chair will not power on after the charger has been connected for at least 8 hours, the batteries may need to be replaced. Power chair batteries will oxidize and go solid if they are not maintained properly or have been stored. Please consult your owner's manual for the type of batteries needed; most likely it is a U1 12 volt 33amp battery, which can be purchased at Batteries Plus or Interstate Battery for around $75-$150 each.
Dec 14, 2010 | Jet 3 Ultra Power Chair
Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter Logo
96 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
