Question about Sony Televison & Video
Red colour is appearing more - Sony Televison & Video
    Top Expert:
  • Sony Master
  • 74,136 Answers
Check its white balance adjustment. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Posted on May 02, 2013
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
Red colour appearing on screen
Your tv could have one of several faults. None of which are to be tackled by anyone except a qualified engineer due to the electric shock hazard.the first problem could be the crt (tube) the second could be the componets on crt base circuit board ie resistors or ic.
With a tv 9 years old it may not be economical to carry out a reair.
Jun 01, 2010 | Thomson 21DC320 21" TV
Red colour disappeared
The bad news is this isn't really a solution. You should seriously consider getting rid of the CRT and going with a flat screen LCD monitor. It is 2009 after all...
Jun 11, 2009 | LG Studioworks 700S 17" CRT Monitor
How to print text using red or blue ink
I would just set the text color to red or blue in your document.
Depending on the program that you use it could have different steps.
Here is steps in Word:
You can change the Colour of your text by highlighting the text and then clicking on the 'A' symbol on the toolbar. This will change your text to the Colour which is underneath the symbol 'A' on the toolbar. To change the Colour, click on the arrow next to the symbol and select one of the colours from the small box which appears. This will change the Colour of your text as soon as you click on the Colour.
Another way of changing the Colour of your text is to go to 'Format' and then click on 'Font'. The font window should appear. Select a Colour from the 'Colour' section. You can see a preview of what the text will look like in the box below. You can also add various effects to your text by using the options in the 'Effects' section. This will also allow you to see a preview in the box at the bottom of the window.
Hope this helps. Please remember to rate this information.
May 03, 2009 | Office Equipment & Supplies
Picture appears "red" where digital pixels should be black
Call Associated Electronics @ 414.281.1000 and tell them what you need.
Mar 23, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Red colour missing
hello
red colour if missing from mother board then you can fix it from graphics properties of your mothrboard driver
but red may also due to monitor,there should be black colour appeaqrs on screen instead of red.
to solve this you have to take your monitor from where you have purchased
if it is in warranty or gurantee then dont take to third party
the fault in monitor may be due to
fault in monitor cable
also check that cable is not loose
try to plug the cable on cpu again
another fault is inside the monitor
also try to on monitor using detaching monitor cable from cpu,message come on monitor ,if in that message red colour appear,then monitor gun is ok
and problem is in monitor due to desoldiring
if you know about soledring than you can fix this problem yourself only if you know otherwise take it to shop from where you sold it
Nov 22, 2008 | Intel D101GGC Motherboard
Colr red
Open the Printer Driver Setup Window and look at colour preference then select manual.
You will then a picture of a boy and adjustment controls for the colour set them to reduce the red and how you would like your photos to appear.
Mar 24, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Colour - red seems to have gone
the problem will be due to the dvd player and if u have an RF out for the player do connect it to the tv and also check the video cable to the tv the color mixing in the dvd player had been in problem due to the absebce of red colour it can only be checked by a technician
Jul 03, 2007 | Philips LX3000D System
Televison & Video Logo
21 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
