Question about Matsonic MS-8188E Motherboard
Matsonic MS 8188E Bios upgrade
I have tried to add a larger hard drive ( original was 20Gb ). Using a 40Gb as drive 0 the boot just hangs , if I go back to the 20gb it loads ok and will see the 40gb when it is drive 1 . I have tried the Matsonic website but it went out of action 20 July this year . The current bios is version 040201 and I belive there is a later version but I need to know where to download it from . Any suggestion please ????? Alan.
  • alpin67 Aug 09, 2007
    Thanks for your input Genius2k4 . I have been down that route , even to just having the 40gb drive as master and the only drive . I believe it to be a block on drives over 20gb which could be a bios problem .
    Alan
  • 27 Answers
Have you ensured that the jumpers on the back of the new hard disk are set correctly? if you want your 40gb HDD to be a master you must set it to master and your 20gb as a slave if you want them both on the same IDE cable look at pic below the image is only a guide as I do not know what HDD you have.
Posted on Aug 08, 2007
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
I have matsonic ms 9097c desktop i try windows xp but its hang up
have u got xp cd ?? if u have put the cd to ur rom n restart ur pc n boot ur pc wit cd so u wil get the installing manu
May 21, 2010 | Matsonic MS8137C Motherboard
I have toshiba satellite L305d-s5934, Blue screen error appear and hang, when i boot or when i press F2 to enter bios... if i full out the hard disk the computer says: no bootable disk and if i press F2 to...
Sounds like your HDD may have gone bad. What is the name/number of the blue screen error? Google it and see what it means. It may be possible to reinstall the operating system to the original factory settings using the recovery partition (this is usually accessed by tapping F10 or F11 while booting, although I read somewhere that you might be able to gain access to the Toshiba recovery partition by pressing "0" (zero) while the computer is powering on).
You can try to recover the computer to factory settings. If your hard drive has enough life left on it, you might be able to then clone it to a new drive. Drive Image XML is a free software that will do this for you (get that from www.download.com). This way, when you clone the drive, you will also clone the recovery partition, so you don't lose that option. Once you have a new hard drive up and running, use the Toshiba Utility to make System Recovery Disks for the future.
One more thing: If you have recently upgraded/replaced the RAM - this might be your problem. Put the original RAM back in and see if the computer boots. If so, you found the culprit.
Feb 26, 2010 | Toshiba Satellite L305D-S5881 Notebook
5.25" floppy
Go into the BIOS SETUP, and change it from '1.2MB' to '320KB',
then 'save' the updated settings.
May 30, 2009 | Matsonic MS-8188E Motherboard
Syntax SV266A Motherboard Hard Drive update
i,d suggest an 80-120 gig hard drive should be sufficent.
if you require larger drive storage. you can add an external hard-drive via USB upto 500 gig usually without restriction.
You can also purchase An PCI Card, with sata connectors. should you wish to take that option. all the above is dependant on how modern your computer system/systems bios Is.
Mike @ Compurepair.
Mar 25, 2009 | Computers & Internet
Cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Can't boot larger than 8gb hard drive
This is a known issue at HP, you should download and install the 68P4M ROM which will solve this:
- Fixes issue where system serial number was lost after upgrade to the new BIOS.
- Fixes variation in the noise of the fan when in motion.
- Fixes error where L1 cache shows only 16KB instead of 20KB in F10 Setup.
- Fixes error where FDISK could only see 8GB of 40GB and 60GB in the Multibay Hard Drive.
You can find it here : http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?lc=en&cc=us&softwareitem=hb-12231-1
Aug 15, 2008 | Computers & Internet
Raid none define
Try getting into your BIOS (usually F2 key at first screen, could also be F10 or Del) and check if your hard drive is in RAID or IDE mode. SATA drives can be run in either. Although it is somewhat odd that a simple mem upgrade could case a raid problem.
Sep 13, 2007 | Select Brands Matsonic mATX 800Mhz s775...
Matsonic MS-8188E Motherboard Logo
514 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Ram kundu
Ram kundu
Robert Karst
Robert Karst
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
