Question about Dell Inspiron Computers & Internet
Touchpad isn't working very well
    Master:
  • 663 Answers
Update the driver of your touchpad. You can get it from the manufacturer's website. Or you can scan your computer with RadarSync so that you don't need to dig for it somewhere. Radarsync will update it for you automatically.
I hope this helps!
David
Posted on May 02, 2013
My Asus Q500A-BHI5N01 touchpad won't let me scroll with the two finger gesture. The mouse works fine, but the touchpad isn't nearly as responsive as earlier. This is a new computer, less tha
Open the touchpad software, ASUS Smart Gesture, adjust sensitivity. Asua support : http://support.asus.com/Troubleshooting/detail.aspx?SLanguage=en&m=Q500A&p=3&s=450&os=&hashedid=n/a&no=1018
Jan 10, 2013 | Computers & Internet
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
Touchpad problem
I am going to assume the touchpad doesn't work, since you didn't elaborate much in your description. If it isn't doing anything, you need to reinstall the drivers for the touchpad. If you have an external mouse laying around, use it to go to the acer site and redownload the touchpad software and follow the instructions to install it. The next time you boot your computer, it will work.
Jul 03, 2012 | Acer Aspire Computers & Internet
My touchpad not working
is their a button above the touchpad? if there is press it, you may have disabled it. if that doesn't work plug in a mouse and go to control panel once booted and verify that the touchpad isn't disabled in device manager.
Jun 11, 2012 | Acer Computers & Internet
Touch keypad on the JGS8750BDS is unresponisve, still getting power as the clock is still functioning. is there a breaker besides the ones on my house I can trip on and off to reset it
the touchpad could be bad or the clock assy. also could be bad,just because the clock still lites up doesn't mean the computer board isn't bad.is there any error codes that come up?also have you tried shutting it down for a while,sometimes the computer board has to be rebooted just like a regular computer,another thing you can try is unplug it,remove the front panel or touchpad,unplug the ribbin and then plug it back in,i've done this before and the touchpad functioned again.also check the tech sheet or book that came with it,on some there's a lock on the touchpad so kids can't start the oven,someone could have locked the touchpad but there isn't any other fuse to check for.on the sears site your touchpad is 252 dollars and the part number is W10206074 the electronic control is 185 and the part number is 8507P227-60 but you can call your parts store and make sure this is correct.did the power go out in your area or anything like that to cause this or did it just stop working altogether.it sounds like a bad touchpad but for that kind of money you might want to call someone in to check it
Dec 08, 2011 | Jenn-Air JGS8750BDS Stainless Steel Gas...
I have Acer aspire 6930 its touch pad not working i installed the drivers also. I am using windows7 OS
Go into your BIOS on the laptop when you first turn it on. Go in there and see if there is a setting for the touchpad. If there is then go ahead and make sure its enabled. If there isn't then you'll need to take apart the laptop and reseat the connector that goes from the touchpad to the motherboard.
If that doesn't do it then you'll need to get the touchpad replaced.
May 27, 2011 | Acer Aspire 6930-6771 Laptop
I Have just got my new Dell xps 15 in mail box. Everything seems to work fine accept the scroller on touch pad. Please help me to solve this problem...the scroller on touchpad is not working at all
If the touchpad is working but the scroller isn't then it sounds like a hardware problem. I would call Dell and try to return it for another one.
May 26, 2011 | Dell F3534 Touchpad
Hi. i have a HP 4510S probook There is an intermittent problem with the mouse where during start uo it says 'mouse not detected' When it does work it's usually for a short while & then...
Do you use touchpad? If so, have you tried reinstall touchpad driver? to get driver for Windows XP, go to here. For windows 7 the touchpad driver isn't listed.
May 25, 2011 | ASUS Eee PC 1000HE Netbook
Hey..i have a hp probook 4420s. its mouse pad ain't working due to which i have to use an external mouse. please tell me how to fix this problem.
First, make sure your trackpad button is enabled... if that isn't the problem, then go to your device manager and check that there isn't a driver issue, if there is you'll see a little yellow triangle next to the category "Mice and other pointing devices".
If there is an issue, highlight your touchpad, then right click and choose "Uninstall Driver".
After the driver is uninstalled, go to your start menu and shut down the computer, then restart it and the new driver should automatically reload into the system.
If its not a driver issue, then its the touchpad itself and you'll have to contact a technician for repair/replacement.
May 18, 2011 | Computers & Internet
Computers & Internet Logo
Alun Cox
