Question about Sony PlayStation 3D display
Lost my Sony Playstation 3D Display base stand screw
Lost my base stand screw for my Sony Playstation 3D Display, the screw that fastens the base to the monitor stand, does anyone know where I can get it or the dimensions of the screw?
welcomejee
  • 10594 Answers
SOURCE: We lost the screws in
You need 4 screws to fix base stand with tv, part number is as follows:
258060801... SCREW, +PSW M5X16
Available in PartStore.com for $5 each, click that link to view screw image and price info.
AC cord part number is as follows:
183514311... Cord AC
Available in PartStore.com for $13
Hope this will help you.
Thanks.
Posted on Nov 15, 2010
  • 1139 Answers
SOURCE: Does the Playstation 3 support
With the new 3.50 update that Sony released it unlocked the ability for the PS3 to play 3D blu rays. Are you sure you have updated to 3.50 as you will need to do this before playing any 3D blu rays. I am sure if you update to this version you will find everything will be fine.
Hope this helps
Posted on Dec 04, 2010
Geekman
  • 32281 Answers
SOURCE: I NEED A BASE STAND WITH NECK for sony bravia KDL60EX700
Try this WEB site.
http://www.nextag.com/sony-tv-stands/compare-html
Posted on May 10, 2012
SD Tech
  • 14553 Answers
SOURCE: screw size for attaching stand for Sony Bravia LCD TV model# 46W4500
while the owner manual does not specify the length etc of bolts it does show there are 4 of them---look like find thread machine bolt---may be able to buy a few at the hardware sore or Home Depot---if the threads are inside the base take it with you as a guide.
http://download.sony-asia.com/consumer/IM/4106869131.pdf
pretty stupid as owner manual has everything including dimensions and weight etc but no list of bolts size.
Posted on May 20, 2012
peasterday40
  • 7 Answers
SOURCE: Light blinks red twice every 5 or so seconds on sony 24in 3d display. Anyone have or know the problem here?
same basic thing happened on my 50 in Hitachi plasma...I removed the back cover and found two capacitors on my power supply swelled...and two chips on one display board burned.Hatachi doesnt make the tv anymore and the parts were going to cost me almost what the tv did new...so...I sold it for parts on ebay...check all the boards for tell tale signs of damage...
Posted on Jul 04, 2012
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    Jan 20, 2015 | Toshiba Televison & Video
    Tip
    How to make your own PS2 stand at home and save money
    How to make your own Playstation 2 stand at home and save $50.
    Playstation accessories are expensive and games are even more expensive. Here is a cheap and fun way of making your own inexpensive PS2 stand.
    The benefits of this stand are
    1) It is light and robust and can be made under $3 or even less ( I really don't know what it would cost I built mine from stuff I had lying around.
    2) It is stable and easily supports the weight of the Playstation 2 console without toppling over. This stand enables you to position your playstation in an upright position and helps you save space.
    3) It ensures that there is adequate air flow all around your playstation console and keeps it cool. This allows you to game for longer periods of time without your console hanging due to overheating.
    Materials that you will require to build your Playstation console stand
    1) Phillips head screwdriver
    2) Penknife
    3) Base of a cd spindle box
    4) Adult supervision (if your prone to injuring yourself)
    5) One screw that will fit into the base of your PS2 console (check at your hardware store to ensure that it fits correctly and does not damage the threads of where it is supposed to fit.
    6) One large metal washer ( inner hole of the washer needs to be small so that the screw can be tightened and doesn't pass through it)
    Builing your Playstation 2 console stand
    1) take the plastic base of the cd spindle. You need to cut out the pole on which the cd's are placed right at the base. You can do this easily with a pen knife or a hacksaw blade as the plastic is soft. (IMPORTANT: BE PATIENT WHILE CUTTING IT AS YOU COULD CUT RIGHT THROUGH IT AND DAMAGE YOUR BASE)
    2) Once it is cut out you should have a hole in the center of the base.
    3) Place your PS2 console in an upright position on this base and center it. If the edge of the base plate is elevated then make the appropriate marking and cut out that portion to ensure that the PS2 console fits snugly into it.
    4) Now simply use the washer and the screw to fix the base plate to the PS2 console and your done.
    5) Place the Console in an upright position and connect all you cables
    CONGRATULATIONS YOUR READY TO HAVE HOURS AND HOURS OF FUN AND NOT DAMAGE YOUR PLAYSTATION IN THE BARGAIN.
    on Jul 02, 2010 | Sony PlayStation 2 (PS2) Console
    I have wall mount and now I need remove the pedestal stand from the TV. But I have lost the manual and can some body explain the steps to remove the stand? Thank you
    Without knowing the model of your TV, it may be tough, but typically it's 1 or 3 types:
    - the whole base is a single piece that slots into the bottom of the TV, with a clip release.
    - the base removes from the stand, and the stand removes from a slot in the TV. This may be fastened with clips or screws.
    - the base is screwed into the TV, and you'll have to remove these to remove the stand.
    If that doesn't help, please provide more details, like the make and model of your TV.
    Dec 18, 2014 | Televison & Video
    Why does my sony 45 inch screen have mostly green color?
    the color tv display used mixing of three colors, (red, green and blue). it lost one color, coomon problems: lose contact of base of picture tube or its wiring, sockets, capacitor dead in rgb section, dead video ic
    Oct 05, 2014 | Sony KP-FX432M91 Projection TV 43 WEGA, 3D...
    I have the sony playstation 3D display. I was wondering whats the best settings for the display. For movies
    If it's a 3D DVD you can have it on the 3D setting, but if it isn't a 3D DVD put it on the regular setting.
    Jan 26, 2013 | Televison & Video
    Sony Bravia KDL-46NX810 shuts off with 3D input only
    Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
    Oct 29, 2012 | Sony KDL-46NX810 46 in. 3D LCD TV
    Got a playstation display and it has a bluish purple vertical line down the tv but it disappears when any red shows up in thae area of the line any ideas what's wrong with it and if it can be fixe
    The display unit is defective, some IC seems to be damaged, it can be repaired from any repair shop, but I don't think the cost will be low, as the display is manufactured by Sony and the spares are not available easily .
    Aug 28, 2012 | Sony PlayStation 3D Display - 3D LED...
    I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
    1 PointsProblem with Toshiba TV Accessories I lost my screws that goes to my tv stand the base I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
    Nov 02, 2011 | Toshiba Televison & Video
    We lost the screws in our move to connect our Sony Bravia KDL-46W4100 TV to the base. Can you tell me what 4 screws I need to buy to connect the TV to the base? Also lost the power cord, what cord do I...
    Thanks.
    Nov 15, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
    Sony PlayStation 3D display Logo
    55 people viewed this question
    Top Sony Computers & Internet Experts
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
