Question about DeLonghi Coffee Makers & Espresso Machines
DeLonghi Nespresso U not puncturing capsule
I have a problem with a 2 month old Delonghi Nespresso U - every 2nd capsule will not puncure, the system stops and all 3 lights flash. The slot lid is stuck and you have to restart the system. The capsule then falls into the bin and the slot can be opened. You can see the puncture mark not going completely through. Not enough pressure is applied to the capsule. Any ideas or solutions? Thank you!
    Master:
  • 563 Answers
Not a fan of nespresso, a lot of cheap plastic. I am guessing the pivot for the capsule puncture arm has worn out allowing some play in it, which is keeping it from closing all the way just a guess, but it is an issue I have fixed before.
Posted on May 02, 2013
  • 6 Answers
SOURCE: the capsule lock system does not make holes in the capsule
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Posted on Dec 26, 2011
Ironfist109
  • 3018 Answers
SOURCE: Nespresso C100 - nothing comes
  • Sounds like you need to descale the capsule.
  1. Remove capsule.
  2. empty capsule, container and drip tray.
  3. Now rinse your machine by pressing the rinse button.
  4. Fill a container with Nespresso descaler and 1/2 liter or water. DO NOT use vinegar, this can ruin your maker.
  5. Make sure to have the pot in place.
  6. Now lift filter,insert filter, close lever.
  7. Now press the two coffee cup buttons buttons together for 3 seconds.
  8. Let the solution run through twice.
  9. Now remove the filter.
  10. Now empty, rinse and fill water tank with fresh water.
  11. Now rinse the machine again by pressing the rinse button.
  12. Press the two coffee cup buttons together again for 3 seconds to exit cleaning.
  • When minerals build up it will overflow as you say it is. Descaling is necessary to proper functioning.
Regards, Tony
Posted on May 17, 2011
espressonist
  • 1711 Answers
SOURCE: My delonghi lattissima is not piercing the
First you need to check the capsule container. Make sure that there are not any coffee remains both the liquid of dry coffee since will blocked the capsule to sit in proper place and thus to be press correctly. If you find anything you need to clean them very well with a warm wet sponge (remove machine from plug).
The second possibility is that one part of the lever and capsule container have brake either a plastic part or a metal rod or a spring moved out of place. In this case you need a new capsule container which you can find in this link.
Here is also you machine parts diagram.
Posted on Jul 31, 2011
SOURCE: I have a dolce gusto and i am unable to remove the
We had a stuck pod in that the drawer was jammed. Turned the gusto upside down and was able to then remove
Posted on Jan 07, 2012
mlenox534
SOURCE: Our machine does not puncture
Just got off the phone with Nespresso 'CS Manager'. THEY REFUSED TO FIX MACHINE. Wanted to charge $125, then lowered to $99. Obviously they DO NOT STAND BEHIND THEIR PRODUCTS. This machine is only 2 years old and was well cared for. Offered to sell me a new one! Told them I am moving to the Starbucks machine, as Nespresso obviously doesn't stand behind their products. POOR CUSTOMER SERVICE. Will never buy, again!
Posted on Nov 16, 2012
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
My Citiz is not puncturing the front (waffled) section of the capsule and is not brewing.
Feb 21, 2011 | Nespresso Citiz C110
With our nespresso machine, when you place the capsule inside & press the button the water runs through the inside of the machine where the plexiglass basket for the empty capsules are
Feb 04, 2011 | Nespresso Citizmilk D120
Our machine does not puncture the Nespresso capsule - so we only get murky water.
I just had the same problem with my new (less than one month use) Nespresso U. (the top of the capsule doesnt puncture and only water comes through). I called Nespresso customer service and a very helpful man suggested I run water through three times by pushing the top slider open with the Longa button pushed and then closed without a capsule in the chamber. That released the air bubble and now I am enjoying a wonderful cappuccino again! The customer service is fabulous, there was never a suggestion of charging me and I was told that Nespresso will send me a free loaner machine if anything goes wrong in the future that can be readily fixed over the phone. The Nespresso U is the best thing I ever bought.
Aug 25, 2010 | Nespresso C100B Essenza Single-Serve...
The capsule lock system does not make holes in the capsule
Oct 09, 2009 | Nespresso Le Cube
Is there a dutch manual for the Delonghi EN 680?
Try the manufacturers web site. They should have the manual in different languages. If not, try a search engine like google and type in "manual for Delonghi EN 680 in Dutch"
Jun 17, 2009 | DeLonghi EN680M Nespresso System Coffee...
Coffee Makers & Espresso Machines Logo
1,228 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
