Proline tw3 eaa-89Downloads Driver
The laptop hard drive developed bad sectors i can not access it and i bought a new one i need drivers for win xp
  • 7 Answers
SOURCE: Need pci modem driver for pavilion laptop model #F4903H
http://www.hp.com/#Support
hp has a great drive download area. just search for you model number; pick your OS; download drivers for the modem; then install them
Posted on Nov 14, 2008
  • 13433 Answers
SOURCE: need drivers for 4930 windows xp
acer does not provide xp drivers for this laptop.
Posted on Feb 28, 2009
Crankstart
  • 696 Answers
SOURCE: Pavilion dv7 laptop driver problem BSOD
DV7 is not designed for XP, to get around the issue you may be able to change the BIOS setting for the SATA controller to work in IDE mode(depending on the BIOS) or you can use the XP installer option to install a SATA/RAID driver during the installer boot sequence. To offer you this I will need to know the model # and Serial # on the white sticker on the bottom of your laptop or the make and model of the SATA controller.
Try the Bios option and reply back with the requested info if it's not a viable option and I will see if there is an XP driver available for your controller.
Chris
Posted on May 17, 2009
sell or burn the laptop ie the only solution for acer with xp.......by person affected by acer
Posted on Jun 25, 2009
Geekman
  • 32281 Answers
SOURCE: HP Pavilion zv6100 laptop CMOS will not recognize the HD
You could have a faulty disk controller. Try inserting a different working hard disk into the HP and see if it can detect it in the BIOS. If not then the disk controller is faulty and this is a motherboard problem. A replacement motherboard may not be worth it, put your money towards a new laptop and put the hard disk into an USB hard drive adapter case and use it as an USB external hard drive.
Posted on Jul 16, 2009
Win xp install problem
According to your problem , the main problem can be of your Hard disk having bad sectors.
This is common problem as the Hard disk goes old.Hard disk having bad sectors can make you lose your data and also it cannot be recovered. So your decision is very right to look for a new Hard disk,this will solve your problem permanently.
Thanks for using Fixya.Have a good day.
Apr 01, 2012 | Computers & Internet
My HARD DRIVER CAN NOT START UP AND IT IS HANGING( LUCKING).I CAN SEE DRIVER IN MY COMPUTER BUT WHEN I CLICK 2 TIMES TO OPEN IT IS TAKING VERY LONG TIME AND HANGING.ALSO SOME TIMES IT GIVES I/O ERROR...
Hard drive access problem, clicking noise indicates a hard drive that is damaged, the clicking is the reading heads trying to access data. You need to replace the hard drive asap and get your data off before it dies.
Download HDD tune from the internet, run it and look for RSC errors and bad sectors, if even only 2 sectors are bad, needs replaced, also if the RSC bar is yellow or red, the drive is on its way out
Mar 29, 2011 | Western Digital Computers & Internet
Hp invent with windows xp pro after restoring to an earlier date says windows cannot start driver corruppted?Did system Diagnostics hard disk test failed test 2 (Comprehensive)...Error: Read Failure
Restoring to an eariler date cannot fix this problem.
If the hard disk diagnostics failed, this could indicate the hard drive is about to fail. The hard disk platter/s most likely has some bad clusters and if any files are located on these bad clusters then you would get a read failure. The number of bad clusters will increase and cause further problems.
Run chkdsk to lock out these bad clusters but this is a temperoary solution and the computer may not be able to relocate the data from the bad sectors to a good sectors.
The fix is to backup your data as soon as possible, then replace the hard drive with a new hard drive and re-install Windows and the Compaq's device drivers.
Jul 22, 2010 | HP Compaq 6735s Notebook
The hard drive crash I can get the recover up but it will not reformat the hard drive it has a lot of bad sector. have new hard drive have windows disk, try loading windows install driver for SATA drive,...
Try copying the driver files (install and otherwise) to a USB flash stick. Put it into a usb port, turn computer on. You should then be able to access the files throughout the installation.
Jun 29, 2010 | Gateway MX6912 Notebook
Windows xp instalation stpos givibg a blue screen in aspire m5640 desktop
Windows Xp installtion give Blue Screen of Death when XP tries to installed devices driver during installation or when the cd is corruptted and cannot be read in graphical mode installation or when the hard drive is corrupted with Bad sector.
Get a new windows XP CD and configure your system BIOS to default setting ( load optimal settings) and configured for IDE drive configuration to compatible mode or disable mode if you are using SATA hard drive.
If problem still occured, get "Bad sector recovery pro" and try to repair the hard disk.If the bad sector are unrecoverable then change the hard drive.
Sometimes, faulty RAM also give blue screen too. Check your RAM too.
Dec 19, 2009 | Acer Aspire m5640 PC Desktop
IHAVE A SAMSUNG R522 LAPTOP HAD IT 6 WEEKS NOW HAVING PROBLEM ONLY JUST FOUND OUT HOW TO BACK UP C DRIVE ONTO DISC ONTO DISC TRIED TO DO IT IT STOPPED SAYING GOT A HARD DRIVE BAD SECTOR, IT TAKES AGES TO...
As you have had it for six weeks only and your HDD has developed some bad sectors, the situation will only get worse as time passes. Ask the dealer to change the HDD. Take a backup of your data (not the complete drive. If you have the DVDs that came with the laptop, then you do not loose any drivers as they are all there on the DVDs. Your firmware and drivers are at
http://www.findmysoft.com/drivers/Samsung-SH-R522-firmware-driver.html
Download and burn them on a DVD. Sometimes one get into a situation inadvertently that extricating yourself out of it becomes cumbersome. This is that kind of situation. Take care of bad sectors first.
Aug 23, 2009 | Computers & Internet
I need to install drivers for a Proline MP3 player
try your player on a computer with a usb 2.0 port and see if it comes up.
this has been a problem for me also using hard drive adapters, win xp wants to see the drive only if it's a master drive.
May 17, 2009 | Audio Players & Recorders
Toshiba MK8034GSX - hard drive - 80 GB Problem
that's not the point..you'll need to go to the toshiba.com site to get that driver set
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
