Question about Husqvarna YTH2348 960430035 23HP 48 Yard Tractor
YTH2348 overheating"
What could be the cause of it overheaTING
What can cause my car to overheat only when my radiator cap is on
Car Overheating? Why your Car Overheats & How to Fix It
www.vikingspeedshop.com/car-overheating-fix-prevent-future/
Rating: 4.2 - ‎51 votes
Oct 30, 2015 - The biggest cause of this is a faulty thermostat that is stuck closed. ... If the radiator cap were to be at fault you most likely would see steam from boiling coolant. My car only overheats when I accelerate hard or drive hard!
Why Is My Car Overheating and What to Do? - EnkiVillage
www.enkivillage.com/why-is-my-car-overheating.html
An overheating car can be caused by many problems. ... Why Is My Car Overheating: Possible Causes .... If you do open the hood, try to do so only when the car is cooled down. ... Never open the radiator cap while the radiator is hot, as the release of pressure could lead to serious ... I wonder if my radiator might be clogged.
Common Causes of Overheating ' ASC Industries, Inc.
asc-ind.com/cooling-system.../common-causes-of-overheating/
... injury, never, ever attempt to remove a radiator cap while the engine is hot! Anoverheated engine can be caused by anything that decreases the cooling system's ...Possible leak points include hoses, the radiator, water pump, thermostat housing, ... Be sure to use the coolant recommended by your vehicle's manufacturer.
Diagnose Engine Overheating - Auto Repair Help
www.auto-repair-help.com/auto.../diagnose_engine_overheating.php
Feb 09, 2016 | Cars & Trucks
What could cause a Mercedes Benz to over heat and keep popping the hose off near the firewall
your building to much pressure and that's related to you overheating ,start by checking cooling system ,possible have it flushed out ,your thermostst my be sticking closed causing overheating, also check radiator cap ,if overheating it should blow off into expantion tank, make sure levels are full , some motors have air bleeder screws that remove the air in the cooling system and that will trap air in the cooling system causing overheating.
Feb 26, 2015 | Cars & Trucks
Start up and start to overheating
Check your antifreeze level and your thermostat. Low antifreeze will cause overheating, sticky thermostat will also cause overheating.
Check your water pump. The internal pump fans may have come off
Nov 11, 2013 | 1997 Chevrolet Lumina
Adjust ignition timing colt rodeo 4x4 3l V6 1996
make sure that your cooling system has no leaks, a common cause of overheating. if there is no leaks , check your ignition timing with a strob, you might want to advance or retard the timing a bit. bad timing also causes overheating
Jun 28, 2013 | Mitsubishi Colt Cars & Trucks
Can a hairline crack in upper radiator hose cause overheating even it there's no leakage?
if the system cannot hold 15 psi of pressure any car will overheat
Mar 03, 2018 | 1994 Mazda 929
Engine overheats and I've changed the water pump already along with the thermostat. What could be the problem?
many things can cause an engine to over heat
Look for any collasped water coolant hose. That will cause overheating'
If the inside of the engines oil cap looks to have a creamy filling in it that will be from coolant mixing with the engine oil. Head gasket leak and can cause overheating
A clogged up heater core or radiator can cause overheating
A loose or worn seal on the radiator fill cap can cause overheating as well
Jun 27, 2010 | Cars & Trucks
YTH200 TWIN HYDROSTATIC TANSMISSION OVERHEATING
call the manufacture for warrenty work if this is still new
Apr 04, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
2001 honda ex-Car overheated and doesnt start anymore!
The car overheated and something caused the overheating. Bad thermostat, low coolant level due to a leak or busted radiator hose, inoperative cooling fan, or a bad water pump. Lots of things can cause an overheating condition and I am not really sure that any blame can or should be assessed to anyone regarding what caused the overheating....something caused it and I would be hesitant to blame the driver. I doubt that the person did anything devious like drain the coolant out. However, poor judgement was used in continuing to drive the vehicle after it overheated. This can cause major problems like a blown head gasket or even a completely blown engine. Maybe the lady panicked or was unaware of the damage that it could cause to keep driving. I suspect that it wasn't something malicious (she probably feels bad enough, already), but just a simple error in judgement. I would probably give her the benefit of the doubt and explain (calmly), the mistake that she made and why it was a mistake. She didn't cause the original problem, she just handled it badly. I would check the condition of the vehicle out and go from there. What's done is done.
Start by trying to find out what caused the overheating and if it caused any permanent engine damage. Some of the things that I mentioned earlier would be a good start, or you could have a certified auto tech take a look at it. It was really nice of you to lend the use of your car to someone. I am really sorry for the trouble you are having and I hope this helped. Best wishes.
Sep 24, 2009 | 1993 Mazda Protege
Husqvarna YTH2348 960430035 23HP 48 Yard Tractor Logo
21 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
