Question about HP Photosmart 635 Digital Camera
Hp photosmart 635 power not on
I can turn on the camera without any problems a few times. The batteries are just fine. I can navigate around the camera menus. I can take pictures with the camera. I can turn the camera off. When it is time to turn the camera back on it freezes up.
  • 2 more comments
  • Mike Bisso
    Mike Bisso Feb 23, 2008
    How do you remove the 'date/time' battery completely.
    I have the same problem with my HP 733.
  • Sus Dixit May 15, 2008
    Camera does not turn on.Have fresh rechargeable batteries in camera.
  • Anonymous Jun 09, 2008
    when i turn the camera on it doesnt let me do any thing not even take pictures. when im ready to turn the camera off it wont do anyhing wat so ever. i put batteries in it and nothing seems to be working. can you please help???
  • Anonymous Aug 05, 2008
    I cant get my Hp 535 to turn on. I gave it new batteries and made sure the memory card was in there but it still just beeps once when I turn it on and then shuts off. What am I doing wrong and is there anyway to fix it?
    Problem Solver:
  • 5 Answers
I have a HP 635 which is the third one after the first two were faulty. This model has a known issue where the 'date/time' battery drains power from the main AA batteries until they are flat.
I have applied a solution by Nspektor from FixYa which seems to have fixed the problem: by removing the 'date/time' battery completely.
I would also recommend using 'ready to use' nimh rechargeable batteries (except Energizers NH15-AAs - they discharge quickly in my experience).
I use Varta 'Ready2Use' 2000mAh nimhs as these are the new generation nimhs that hold 80% of their charge for months rather than losing about 1% of charge per day like normal nimhs. 'Ready to use' nimhs are pre-charged so can be used straight from the packet unlike normal nimhs.
If possible I would return your HP 635 for a refund or at least a store credit, and choose a different camera brand.
I hope this helps.
Posted on Feb 19, 2008
SOURCE:
Tip
@ Kath17: It sounds like the charger. If you bought new batteries and the...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Feb 19, 2008 | Samsung Digimax D53 Digital Camera
Hp photosmart camera stopped working
It sounds like a dew problem. Has it been left for a while without use?
Leave it turned on in a warm room for a few hours and it should start working again. Hope this helps.
May 10, 2012 | HP Photosmart 435 Digital Camera
Where is the time/date battery located? My 635
Hi.
If you are using the batteries that came with the camera or just regular or Lithium batteries, this could be your problem.
At Walmart or any discount store, buy 2 NiMH rechargeable batteries with the charger. Believe me, years ago when I bought my first digital camera, the same thing happened to me. I was only getting a few pictures and the batts went dead, especially if I was using the LCD screen and not the view finder, or using the zoom which both of them take alot of power.
NiMH batteries are made to last using when using digital hardware.
Hope this works for you!!!!
Oct 25, 2009 | HP Photosmart 635 Digital Camera
HP Photosmart M22 Digital Camera
i still can't solve my problem with my camera.
the screen still displays a red color
Feb 21, 2008 | HP Photosmart M22 Digital Camera
Camera problem
Sorry to say; the camera is faulty and needs replacing.
I have a HP 635 which is the third one after the first two were faulty. The current one has had excessive battery use problems but I think it has been rectified by applying a solution from Fixya (Nspektor).
I would recommend returning it and getting a refund, or store credit at least, and buying a different brand of camera.
I hope this helps.
Feb 17, 2008 | HP Photosmart 635 Digital Camera
Dark screen on HP Photosmart E327
Same problem here, i upload the pics on my computer, then i turn off my cam, few minutes later try to turn it on, but no success, still have the blackscreen. I try to change the battery, reset it (15s without the battery, another 2 hours but no success), format the memory card (even without the memory the cam doesn't turn on).
Jan 03, 2008 | HP Photosmart E327 Digital Camera
Battery Life
This is a typical problem with these cameras. The culprit is a failed onboard battery. The battery is for retaining the time and date while replacing the removable batteries. If you put batteries in and set the time and date- then remove the batteries for about 30 seconds- put the batteries back in- if it asks you to set the time and date again the onboard battery is no good. If you remove the onboard battery your camera will be very usable and the batteries will last 100 times longer. If you can change the batteries quickly you will not have to set the time and date because there is a small capacitor that will retain a charge, in other words it works better without the battery. I have done this to about 15 of these cameras and all worked great afterwards. You will need a precision philips screwdriver to remove the 7 screws that hold the case together. The onboard battery is small, like a hearing aid battery, mounted on the lower board just behind a piece of brownish cellophane like material. Just cut the material open and look in there between the boards and you will see it. It is mounted flat grap it with some precision long nose pliers or tweezers, wiggle it until the solder joints fail and remove it. Re-assemble and your paperweight is a camera again. If you do it wrong ,which is unlikely, you still have a functioning paperweight.
Dec 04, 2007 | HP Photosmart 635 Digital Camera
Camera Wont turn on and blue light flashes
The possible answer is that batteries are past thier best now and even a 'full' charge is not delivering enough power. treat your self to new batteries.
Aug 13, 2007 | HP Photosmart M425 Digital Camera
HP Photosmart 635 Digital Camera Logo
184 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
