Question about Sharp Microwave Ovens
R - 2110 jw
How to remove from wall
  • Sharp Master
  • 9,098 Answers
The service manual is here:
http://www.microwavedisplay.com/r2110jk_r2110jw_sm.pdf
You can order Sharp parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
Posted on May 03, 2013
Removing unit
To remove, you will need to remove four bolts on the top of the unit.
Unplug it first, then remove the two bolts nearest the wall first. It would help to place something under the front of the unit about two inches shorter, to catch the unit as you remove the front bolts. The bolts are long, so be prepared for a lot of turns. A ratchet helps. The unit will lower in the front as you remove the last bolt. There is a bracket screwed to the wall behind the unit, with a lip at the bottom that holds the back of the unit. After the front has lowered, lift the back up about an inch, and pull the whole unit away from the wall. Remember to pull the power cord out of the cabinet before moving the unit away. Hope this helps.
Jun 14, 2014 | Kenmore 62702 Microwave Oven
Tip
GRANNY?S NUKE NOTES
All of my tips have been tampered with. I deeply regret I must remove the content from these tips. I will not write another tip for fear of further tampering of my literature. If you have any questions I am on facebook.
JW Webster
on Dec 07, 2009 | Microwave Ovens
How to remove Kenmore Quicktouch micro hood
If it's like most above-the-range microwaves, there will be 2 or 3 screws holding it from above, inside the cabinet
While supporting the unit from below, remove screws.
The rear of the unit is supported by hooking onto a bracket that is screwed to the wall behind it.
The rear needs to be lifted, then the unit should pull away from the wall. Requires some muscle.
Mar 02, 2014 | Kenmore 66469 / 66462 / 66464 Microwave...
How do I remove my Sharp R 1870 from the wall
PUSH UR MICROWAVE VERTICAL. IT WILL DISMOUNT ON ITS OWN.. THEN U CAN UNBOLT THE FITTINGS FRM UR WALL..
Aug 24, 2012 | Sharp R-1870 Convection/Microwave Oven
How do i remove sharp microwave from wall model
The only problem that ricksterboy doesn't list, is there are also two screws located underneath as well. You have to take off the filter screens to find them. They secure into steel supports inside the microwave.
No getting the micro off the wall w/o removing them, or using a sledge hammer...which after all the time we used trying to get the thing off the wall, seemed like a good theraputic option.
Lucky we took off the vent cover and discovered the additional anchors.
Aug 22, 2009 | Sharp Microwave Ovens
I have ge under cabinet microwave model jvm1331 004 that i need to remove. what holds the unit in place?
Look in the cabinet above the microwave. You should see a vent if it is vented outside. You will need to remove the vent. Then look in the same area to find two screws that will need to be removed. Disconnect the power cord and have someone hold the bottom of the unit and remove the screws. It will fall at this point so hold it good. With the screws out and vent removed you will be able to let the front of the microwave down a little. This will allow you to now lift the back to release it from the channel hook in rear. Then you will see the mount plate on the wall. It should have screws securing it to the wall on stud locations. remove these screws and remove the wall plate. Hope this helps. Good luck.
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove an old amana microwave from the wall model MVH-9T
remove grease traps on underside. Look inside and remove
clip(s) to wall
Open cabinet above, remove two bolts holding microwave
Slide out.
Apr 27, 2009 | Amana MVH220E Microwave Oven
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do i remove the microwave oven off the wall
hello I am trying to remove my microve from the wall I did remove 2 bolts on top,I am non able pull
the unit out.anybody can give me suggestion. dave
Sep 11, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
