Lg hdd hxg1
What is the power supply to this hard drive 220volt or 12 volt
  • 193 Answers
SOURCE: external HDD won't start up
putt the actual hdd in master and the 1 ur having problem with in slave mode boot windows go 2 controle panel administartive tools and device manager or manegment somthink like that and in the diagnostik box take the last option frome the second 1.u must see ur seond hdd that u put on slave..format it...after that putt it alone and boot frome windows xp and install ur windows this will work
Posted on Feb 13, 2008
SOURCE: power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Posted on Nov 24, 2008
  • 21 Answers
SOURCE: seagate hard drive will not power up
You have to be running NT, XP or Vista to access the drive. I take the power cable out, then plug it back in. Or try rebooting with the hard drive plugged in. Also purchase a USB Extension port so you can unplug the USB when not in use to stave off overheating. Go to Seagate and download Seatools. Also Download the source code for the drive while you are there.
Posted on Jan 27, 2009
tomba_nzxt
  • 205 Answers
SOURCE: Hi, My buffalo external HDD power supply seems to
set your bios to boot from your normal drive, not the ide buffalo drive ...
Posted on Aug 10, 2010
  • 79 Answers
SOURCE: Is 12 Volts DC and
The correct adapter is 12V 1.5A, 500 mA will not be enough current for the drive.
Posted on Apr 19, 2011
What size power supply for the wd50001032001 how many volts ?
It would appear to be 12 VDC for that type of western digital my book external hard drive. Found a oem selling them on Amazon: T-Power AC Adapter for Western Digital APD DA-48m12 My Book Pro Edition 500GB~2TB drives WD50001032-001 WD4000D032 HDD WD1600B014-RNU WDXUL2500BB wd6400h1u WD1200B007 HDD WDG2TP10000N NAS Network HDD
Nov 02, 2017 | Power Computers & Internet
Hi, in Antec 300watt power supply there is 3 cables or input or current 220volt. The cables are Black, Green and white. Which one is earth, which on is live(positive) and which one is negative?
For 120 volt operation use
black for the hot, White for the natural, Green for earth ground.
For 240 volt operation use;
Black and White for the 240 volt and Green for earth ground.
Black is generally designated as the "Hot" or "positive" .
You must make sure the switch on the power supply is set for the voltage you are using. ie: 120/240
Dec 15, 2014 | Antec Computers & Internet
What volt adapter for WD 3200H1U-00?
Most external hard disks use a 12 volt 2 amp power supply. The modern ones are small and cheap. Be aware the power plug should be the same as the power plug on the old power supply. and the polarity also.
Jul 09, 2014 | Western Digital My Book Essential 1TB...
The box is powering on but not powering any of the fans or any of the hdd's
A bad power supply can cause this. The 12 volt rail could be dead and not powering the hard drive and fans, but the 5 and 3 volt rails are good and powering the motherboard. Test and or replace your power supply.
Aug 16, 2013 | Mediasonic H82-Su3s2 ProBox 8 Bay External...
Need a power supply
I use the adjustable power supplies you can get at Radio Shack.
Nov 05, 2012 | Computers & Internet
My external hard drive fails to spin
The hard drive needs a proper regulated power adapter for the hard drive to work.
If the hard drive is a 5.25 inch drive it requires 12 volts and 5 volts power supply.
If the hard drive is a 3.5 inch drive it requires a 5 volt power supply.
Apr 10, 2012 | Seagate Computers & Internet
I have a simpletech 120 GB external USB hard drive with NO power supply. Do you know what the power rating is (ac or dc, how many volts, amperage...) or where I can get a new power supply for it? -Thanks
12VDC, 1.5A external power adapter Well that is what this page says, it's not your 120GB drive but unsure if it's no the same model maybe. However all external HDD that need a power supply should be needing 12 volts, as they are just internal drives mounted in a shell and some simple circuitry to power and connect it.
May 22, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
I have an emachine t2885, when i hit the power button, i dont get any power to the computer, but the keyboard, speakers and monitor lights go on, but no power to the computer, help
I'm going to guess pwr supply 12 volts side. The 5 volts side lights up keyboard and mouse; both get replaced when they fix (replace) the power supply.
The hard drive and dvd player us the 12volts side.
Check 12 volt supply side if low disconnect hard drive check voltage again,, if 12 volts hard drive bad,,, if low disconnect dvd,,, if 12volts connect hard drive,,,if 12 volts dvd bad. of course this scenerio can go the opposite way. Do you know how to use a multimeter? Black box maintence is exciting.
Nov 27, 2010 | E-Machines eMachines Desktop PC
Dp-01fx tascam
Since the unit powers up and displays an error message it means that the power supply is working to some extent. The hard drive is probably malfunctioning and needs to be replaced. The DP-01 I have uses an 40 pin IDE 3.5" hard drive so finding a replacement should be easy unless it needs special formatting like TIVO drives.
As for the first solution - why do you think a PC hard drive needs -5v? The PC drive power connector has four pins - two grounds, 5v and 12v.
Mar 30, 2009 | Tascam DP01FX All-In-One Recording Package...
Computers & Internet Logo
311 people viewed this question
David Payne
David Payne
