Question about Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
Cth 151 starter solenoid - Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
How do I reach the top starter bolt from the wheel housing?
Look for an access area in the wheel housing. It should have a plastic or rubber cover with plastic retainers holding it in. There are a couple types of retainers used; some just have a flat head about the size of a dime or nickel. These can be pried off. Some have a center pin that has to be pried up and pulled first. Both types may break but can be found at your local autoparts store. There is a special tool that makes this easy, but you can pry them with a screwdriver or chisel. Also sometimes the rubber cover just needs to be lifted up.
Yes, this response is generic, but I found many makes and models have these access holes.
See fastener types.
http://www.clipsandfasteners.com/Autobody_Clips_And_Fasteners_s/151.htm
May 18, 2014 | 2002 Ford Explorer
Tip
Equinox EQ-310-cth thero/hygro/clock
i have Equinox EQ-310-CTH
thermo meter how adjust the clock
on May 26, 2010 | Health & Beauty
Bamboo fun CTH-661 cable broken
http://compare.ebay.com/like/350597727368?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Here is the website you can order a replacement cable from. Its on ebay, and pretty cheap.
Sep 20, 2012 | Wacom CTH661 Bamboo Fun CTH-661
I have just bought a second hand cth 180 xp. It's
you will get all that on the engine manufacturers web site under that size engine
Jul 08, 2017 | Husqvarna Garden
Putting starter back on vechicle need help with wiring
LOOKING AT STARTER WIRES.BATTERY CABLE POSITIVE CABLE GOES TO STARTER SOLENOID POSITIVE POST TERMINAL THAT IS THE LARGE STUD IN THE STARTER SOLENOID.. THE OTHER TWO RED WIRES WITH LARGE RING TERMINALS ALSO GOES TO THE STARTER SOLENOID POSITIVE POST TERMINAL.THE PURPLE WIRE WITH SMALL RING TERMINAL GOES TO S OR SWITCH POST TERMINAL.ON STARTER SOLENOID LOOK AT THE STARTER SOLENOID YOU WILL SEE LETTERS R AND S ON SOLENOID THE PURPLE WIRES WITH SMALL RING TERMINAL GOES TO S STUD TERMINAL ON STARTER SOLENOID.
May 26, 2011 | 1999 Oldsmobile Alero
Starter solinoid replacement enstruction
SOLENOID REPLACEMENT
(see Figures 5, 6 and 7)
Prior to removing the solenoid from the starter motor unit, matchmark the solenoid-to-starter motor housing position, as shown in the accompanying illustration.
  1. Remove the starter motor from the vehicle.
  2. Detach the solenoid-to-starter motor wire from the solenoid terminal.
Do not disassemble the solenoid; if the solenoid is defective, replace the entire unit with a new one.
  1. Remove the two attaching screws, then slide the solenoid out of the starter motor housing flange.
Fig. 5: Before removing the starter motor solenoid, matchmark the solenoid-to-starter motor housing relationship
Fig. 6: Disconnect the field coil lead from the solenoid by loosening the retaining nut ...
Fig. 7: ... then remove the two attaching screws and separate the solenoid from the motor housing
To install:
  1. Inspect the solenoid plunger joint for wear or other damage. Replace it, if damage is evident.
  2. Apply Suzuki Super Grease A (99000-25010) or equivalent, to the solenoid plunger and to the tip of the lever arm (inside the starter motor-to-solenoid housing hole).
  3. Insert the solenoid into the starter motor housing, ensuring that the matchmarks made during removal are aligned.
  4. Install and tighten the two attaching screws securely.
  5. Attach the starter motor-to-solenoid wire to the solenoid terminal.
  6. While the starter motor is removed form the vehicle, perform the testing procedure to ensure that the new solenoid functions properly.
  7. Install the starter motor.
Hope this help (remember rated and comment this).
Mar 23, 2010 | 1994 Geo Tracker
How do i reset the entire system back to default? Previously someone had put an admin lock on it so now i cant use it properly and i need to reset the menus.
Hi
· It is called the Cold reset
A cold reset resets the values of permanent storage variables back to factory default. Often this is
necessary for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
● Embedded Jetdirect IP address
● SMTP IP address
● LDAP IP address
● Embedded Web server password
● All control-panel configurable items
The following items are NOT cleared during a cold reset:
● Local address book e-mail addresses
● Real-time clock (date and time)
● Page counts and maintenance counts
● Product serial number and formatter number
● Service ID
● Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. While the product is performing its memory count, hold down the #6 key. When the three status
LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | HP Digital Sender 9250c scanner Printer
We have a husqvarna cth 170 and we cant seem to reverse it... have any ideas on how?
I have a Husqvarna YTH2348 that clicks when i try to start... I had the battery tested and changed the solenoid and still won't start. How do I check the starter????
Jun 05, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Manual trouble
Sorry can't help...
Feb 09, 2009 | Lakewood CTH-2 Heater
Water won't shut off
check the timer on the machine. it could be a mechanical or electronic timer. the timer's output goes to a water solenoid valve. could be the solenoid itself is faulty, but it all seems to point towards the timer - because you say it works fine normally. Is this a bunn coffee maker?
Sep 13, 2007 | Brewmatic 151 Coffee Maker
Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042 Logo
46 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
