Question about Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher
GE dishwasher will not start cycle
My 8 year old GE dishwasher has power and water supply hooked up, but when engaged there is only a humming sound but no water pumped into the washer??? Could it be like on a clothes washer, a defective water inlet valve? Thanks,
  • 641 Answers
Yes,it could be a deffective inlet valve. But before replacing it check first water inlet line's filters (on its both sides) In case it will not help- test that the valve get power. In case it get power and doesn't work - You can easily open the valve and clean it from scale or other dirt. Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new one Good luck!
Posted on Aug 10, 2007
Dishwasher hums but does not start
sounds like the pump is shot.
Feb 08, 2018 | Maytag Dishwashers
GE Nautilius 24" built in about 6 yrs old won't start - it hums and goes through the cycles but doesn't run. Water came in and now won't drain either
Sounds like one of two things 1. The timer unit is gone, that would need replacing. 2. the syphin relay is stuck, this is located below the syphin on the underside of the dishwisher. BE CAREFUL! You will be dealing with electrics.
Aug 11, 2010 | GE Nautilus 24" Built-in Dishwasher
The dishwash is not washing, it's running but there is no water. The washing cycle is completed but nothing has happen, this recently started.
Sounds like a bad water valve or the water supply is cut off. If the water supply is not cut off then try hooking up 120 volts to the water valve. It should buzz or hum and let water in. If no water goes in then change the valve.
May 15, 2010 | Dishwashers
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
GE Dishwasher that will not advance cycles
sounds like inlet valve is not opening or water has been turned off or kinked.
Sep 14, 2009 | GE Dishwashers
GE diswasher hums but will not start cycle and starts to smell ho
Hi, Have your freind check and see if the water supply line under the sink has been turned on. The hum you are hearing could be the inlet valve. Please let me know if this has been helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | General Electric CDW9380N Built-in...
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Potscrubber Dishwasher Stuck on Cycles
Could be a defective cycle timer
Jan 30, 2018 | GE Dishwashers
GE profile dishwasher does not drain out aat end of cycle
I just fixed the very same problem by replacing the piston and nut (part # WD24X10018).
Jan 07, 2009 | GE Dishwashers
Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher Logo
296 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
