Question about Stryker MicroDebrider ENT Surgical
Sharper image microdermabrasion system hf650 instructions
Power
I have a sharper image Power Tower 200 and I lost my power adapter I need to know what the voltage is so I can buy another one the voltage on the output
On 2000-10-30, the Consumer Product Safety Commission (CPSC) publisheda recall regarding Sharper Image Power Tower CD Rack due to a potential fire & burn hazard. This product sold new for about $160.
Just found this on the net, so it's a good job you lost it!
Apr 28, 2016 | Sharper Image Audio Players & Recorders
How do I work the flashlight on the sharper image pocket power dual USB charger
Please refer to your instructions, or contact Sharper Image customer service.
Jun 05, 2015 | Sharper Image Air Purifiers
Customerservice
Amy, I'm sorry this happened to you. But Fixya is not linked to any firm that sold your Microdermabrasion System (Professional Skin Rejuvenation). Here are jus a bunch of amateurs and professionals, who like to help people with technical questions. The only thing I can tell you is this:
When you have an electric or electronic apparatus, with a (rechargeable) battery in it. It won't work if you left it unused and un charged for a few years. Only lithium batteries, are known for long life. They can be o the shelf for 10 years and still work. But all other batteries are gone when not used in just a few years.
If you can replace the battery, it is possible your Microdermabrasion System will work as you expected.
So don't expect an answer from a sales person that offers you payback or something you where thinking of. Try to find the firm that mad this equipment.
Jan 18, 2014 | Cameras
Need instructions and codes to program Sharper Image Jumbo Remote
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals.
I hope that helps.
Mar 22, 2010 | Sharper Image TI150 Iron
Instruction book for a micro cd shelf system
not solved - but not going to pay for an instruction book when it should be a 'downloadable' item by sharper image
Dec 03, 2009 | Sharper Image SO330 CD Shelf System
Sharper image power tower 200
There is a small 1 1/2 inch O ring style belt that connects the motor to a set of gears. This belt is most likely broken and needs to be replaced.
May 17, 2009 | Sharper Image Power Tower Motorized DVD...
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
I Am trying to program the sharper image jumbo sized universal tv remote.I can;t get the Samsung dvd/vcr combo to except any code listed in the instruction manual
The Jumbo Touch remote does have a learn function which may be helpful in controlling your Samsung DVD/VCR combo.
I hope that helps.
Sep 12, 2008 | Sharper Image Professional Plus Ionic...
..check it out....
http://www.blurtit.com/q717681.html
Feb 17, 2008 | Televison & Video
Stryker MicroDebrider ENT Surgical Logo
46 people viewed this question
Top Stryker Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Stryker Science and Laboratory Expert? Answer questions, earn points and help others
