Question about Home Security
Merlin C945 remote intermittent range
Intermittent fails to open door
  • 3197 Answers
SOURCE: Craftsman Garage Door Opener Intermittent
Yes your receiver is bad and it is part of the logic board.
Posted on Jul 20, 2009
  • 158 Answers
SOURCE: We are having intermittent problems with our 2
Greetings LiftMaster Owners:
You are probably getting signal interferences from other devices in the neighborhood or from your home that are on the same frequencies as your remotes and garage door openers. Weather conditions can lock signals and frequencies into a much smaller area concentration causing these interferences. Check you home owner manuals for the grarage door opener and see if there is an adustmen on the garage opener that can strengthen your signals. Good Luck
Posted on Oct 14, 2009
  • 8457 Answers
SOURCE: Intermittent beeping sound
Check the main battery,it might be dead,beeping sound it a require a another battery.
Posted on Apr 14, 2010
  • 3197 Answers
SOURCE: remote code for a merlin power lift
I think you will have better luck checking around the Australian forums for help with this door opener.
blanchettohd
  • 143 Answers
SOURCE: I have a Merlin Powerlift-Model 2500L Garage door ...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
Posted on Sep 03, 2010
How to program a remote control for Merlin Garage Door
Each manufacturer of aftermarket remotes for Overhead doors has a specific sequence for a specific door opener mfg and model #. And those sequences are include in the printed matter in the packaging of the remote. If you have Merlin remote and Merlin opener contact the local Merlin installer for the sequence.
Oct 13, 2014 | Building Materials
Chamberlain remote garage door opener is intermittent
You probably have interference from somewhere. I had the same problem, turns out it was the LED light bulb I put in the opener. As a result, the door would always open, but hardly ever close. I called this intermittent, but there clearly was a pattern.
Dec 20, 2012 | Chamberlain Home Security
My wife and I have the same type remote. Hers works well and mine has for the past six months decided to work when it wants, no matter how many times or however long you hold the button down it fails to...
1. Change the battery in your remote 2. Are you using you remote in the same way as your wifes, ie on the cars sun visor, try putting both remotes in the same location and activate the garage door with both remotes several times if yours fails your remote has an intermittent fault.
Dec 28, 2010 | liftmaster 373lm Liftmaster Craftsman...
Remote code for a merlin power lift
Mar 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
11 year old Viking VGSU161-6BSS with intermittent gas smell.
STOP USING COOKTOP AND TURN OFF GAS AND GET SOMEONE AUTHORIZED IN AS SOON AS POSIBLE .
Oct 22, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Jul 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless key pad and remote openers for the cars work intermittently have tried re-learning
Your remotes and your keypad are small transmitters that send a signal to the receiver. If all your units are intermittent then it is the receiver that is bad. The receiver is part of the logic board.
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Intermittent remote car door opener
many vehicles can be programmed by using the internal lock switch to set user preferences...find user manual to see if its available on your vehicle
Mar 29, 2009 | 1998 Ford Explorer
Home Security Logo
24 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
