Enhanced cat5e How to wire enhanced CAT5E connections?
  • 32,281 Answers
osborne382
  • 306 Answers
SOURCE: Cat5e to RJ11
You wont be able to....You need another NIC...you can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Posted on Nov 10, 2007
  • 57 Answers
SOURCE: Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Posted on Nov 22, 2008
ljharb
  • 21 Answers
SOURCE: Dont know how to hook up cat5e cable to a leviton cat5e jack
Those two jacks are telephone jacks (RJ-11) not ethernet (RJ-45). The jack marked telephone is for a phone, and the jack with a rectangle symbol is for the telephone line into the wall.
You need to buy an ethernet PCI card - without one you can not use a cat5e line (which has an RJ45 connection).
  • 101 Answers
SOURCE: can cat5e cable be wire wrapped?
I tried the same thing once, the diameter and the twist make it useful only in desparate times when you just can't find any mylar wire to use. Been there, done that, now you have the T-shirt. I do use the wire for patching and repair but again it is just much larger than patch wire and not nearly as flexible.
Posted on Jul 23, 2009
sarasvatas
  • 329 Answers
SOURCE: repeated next faults on a cat5e permanent link
networking pairs are 1,2,3,6 it doesnt matter 4,5,7,8 is working or not
Posted on Sep 30, 2009
I need networking cables, which cables are best for use.
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Apr 01, 2014 | Computers & Internet
Ethernet wired
when you use windows 7 or 8 Operating system, and the internet icon have yellow marking, the problem is in the cat5e wire, the 1 out 8 wire of cat5e are disconnected.
Mar 25, 2013 | HP Pavilion dv9000z Notebook
GE Network & Coax Wall Plate has 8 wires of solid colors. My CAT5E cable has 8 wires, only 4 of which are solid and correspond to 4 of the solid colors on the wall plate. The other 4 wires on the CAT5E...
Hello
Your cat5 will make up 4 pair. org/org/wht being one pair and so on.
So as long as you keep them in pairs you will be ok.
Meaning. Pair one from cat5 org and org/wht to wall plate wht and brn.This would be one complete pair.So the wall plate colors are different from cat5 but as long as you stay in pairs and go from left to right on your conections you should be ok.
Jun 05, 2011 | Computers & Internet
There is 4 pair cat5E caple with one pair defective, how can u trace the defective wires. Are you capable of putting connectors on a faulty cate5E cable, having 2 wires defective out of the 8.
To use 8 wires cable for 100BaseTX connection only four wires are used, pin 1,2,3 and 6. You can find defective wires by using wirescope which can detect which wire has problems. If these two wires are not one of these I had mentioned according to standards 568A or B (it depends of the rest of the network) then you can use it if not then take care wher to put these bad wires but not on pins 1,2,3 or 6. Take care to document this. The best solution is to replace this bad cable with good one and do everything according to standard procedure.
Dec 14, 2010 | Cat5e Computers & Internet
What is UTP CAT 5e cabel?
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Jan 13, 2009 | Intellinet Active Networking CAT5e UTP...
Nov 22, 2008 | Leviton Computers & Internet
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
Cat5e 350mhz wire
What you can do with the cat5 cables is plug the wire into the PS3 and the other end into your home router or switch. This might be a problem if your router or switch is in another room or so but it will most likely give you less lag.
Hope this helps, let me know if ya have problems connecting if you decide to use the cat5 wire but it should be about the same setup as using wireless.
Aug 14, 2008 | Cat5e 10ft White 350MHz Stranded Snagless...
How to wire up a cat5e faceplate with cat 5e wire
If you want to learn how to wire cat5e, here is a video:
http://www.serverracksandcable.com/cat5-cat5E-cat6-cat6A-cables-limitations.php
Mar 07, 2008 | Computers & Internet
Cat5e to RJ11
Nov 04, 2007 | Cat5e Cat 5E Modular Plugs - For Round...
Computers & Internet Logo
467 people viewed this question
David Payne
David Payne
