Question about Cell Phones
IPhone MD126LL/A where is the Sim card located
2 Suggested Answers
  • 5 Answers
SOURCE: changing sim in iphone cause overheating and rapid battery drain
it is the sim card brother not the charging jack k you must upgrade your iphone version to use the simcard again and prevent rapid battery drain k. or you can change sim either. k
Posted on Dec 20, 2009
Does my zte800 have a sim card?
Remove or switch the SIM card in your iPhone or iPad - Apple
https://support.apple.com/en-us/HT201337
AppleDec 11, 2015 - After you remove or transfer your SIM card, insert the tray completely and in the same ... For example, a SIM tray from an iPhone 6 will not fit in an iPhone 6s. ... Find out which SIM card your devices uses. ... Shop the Apple Online Store (1-800-MY-APPLE), visit an Apple Retail Store , or find a reseller .
Why Does My iPhone Say No SIM Card? Here's The Real Fix!
www.payetteforward.com > Tech Blog > iPhone
Nov 28, 2014 - You didn't take the SIM card out of your iPhone, and now you can'tmake phone calls, send or receive text messages, or use mobile data.
Does iPhone have a SIM card? - EveryMac.com
www.everymac.com/.../iphone-sim-card-troubleshooting-...
EveryMac.comHow to access the iPhone SIM card, which iPhone models have Mini, Micro and NanoSIM cards and how to upgrade from an old iPhone to a new iPhone.
Jan 12, 2016 | Cell Phones
Tip
How to replace iPhone SIM card
The only thing that you must have is a SIM eject tool or simply a straightened paper clip or any pin-like object hard enough to push-open the SIM tray. BTW, this SIM eject tool came with the box when you bought your iPhone.
Here are the steps:
First, refer to the image below to locate the SIM card tray. To pull it out, you need to insert the SIM eject tool (or the paper clip) on the tiny hole on the top of the iPhone 3G or on the right-side of the iPhone 4. Push until the tray pops out.
NOTE: The tiny hole found on the top of the iPhone 4 is not for the SIM card tray, it is a microprhone. Please do not insert any thing in there.
Once the tray pops out, pull it out completely and replace the SIM with any SIM you want.
When you're putting it back make sure that the SIM carrier logo is facing the front of the iPhone. Don't force it if it get stuck, just pull it out again, and gently put it back.
Here's an image for your reference:
Please read my other tips:
JAILBREAK
http://www.fixya.com/support/r5452955-jailbreak_all_idevices_iphone_4_3gs
UNLOCK
http://www.fixya.com/support/r5537989-unlock_iphone_4_3gs_3g_or_older_ios
on May 06, 2010 | Apple iPhone 3G
How do you get the sd card out of the phone
iphone 4s (as with any other iphone models) don't have an expandable memory therefore iphones dont have a SD card slot.
The only thing that is removable is the sim card. if that is the case there should be a sim ejector that can be found inside the iphone box with the manual. insert the sim ejector tool (or a pin) into the sim card slot located on the right hand side of the device (i.e. opposite side to the volume and mute buttons) once you do that the sim should come out on a sim tray.
hope it helped :)
Aug 26, 2014 | Apple iPhone 4S
How to insert sim card in iphone 3g
Turn off your iPhone 3G and make sure any cords or connector cables are removed from the device. Then, hold your iPhone 3G upright.
  • Locate the Sleep/Wake button and headphone jack on the very top of the iPhone. Between these two components you will see a very small hole.
  • Insert the tip of a paper clip into the hole to release the iPhone's SIM card tray. The small tray will pop up relatively quickly from the top of the iPhone. If there is already a SIM card in the tray, use your fingers to remove it.
  • Insert the SIM card you want to install into the phone facedown in the tray. Make sure the side without the reflecting panel is inserted first.
  • Press the SIM card tray gently back into the slot until you hear it "click" into place. Now turn your iPhone on. All of the information on the card will now be in your iPhone 3G.
  • Mar 16, 2011 | Apple Computers & Internet
    How do you put the sim card in the apple i phone 4
    Apple iPhone 4 uses a Micro SIM which is 15 mm × 12 mm in size while the standard Mini SIM is 25 mm × 15 mm in size. To insert a SIM in iPhone 4, follow the steps below:
    1. Take a simple paper clip and make it straight.
    2. Check the right side of your iPhone 4 to locate the SIM tray on the Right side of the iPhone.
    3. Insert the pin into the small hole and push it slightly until the tray pops-out. Now pull out the Sim card tray with your hands.
    Mar 10, 2011 | Apple iPhone Smartphone
    How do you undo the back of the iphone and change sim card
    You don't.
    The SIM card isn't in the back of an iPhone. It's located on top.
    http://www.maclife.com/article/how_to_remove_the_iphone_sim_card
    Jack
    Jun 30, 2010 | Apple iPhone Smartphone
    Sim card location on apple iphone 3g
    On the top of your device you will find the SIM tray. There, you'll see a little hole. If you have the SIM eject tool, insert its end firmly into the hole, until the SIM tray pops up (a paper clip would also do the trick, instead of the SIM eject tool). Remove the SIM tray, place your SIM card into it (aligning the angled corner), and carefully place the SIM tray (along with the SIM card) back to its place.
    Hope it works for you.
    Cheers! Carlos
    May 11, 2010 | Apple iPhone 3G
    Can't change sim card
    Hello.
    The SIM card slot is located at the top of the iPhone, between the headphone jack and the power button.
    Take your paper clip and insert it into the little hole. Then firmly push down until the slot pops up,
    Hope this helps.
    Jan 10, 2010 | Apple iPhone Smartphone
    Changing sim in iphone cause overheating and rapid battery drain
    Aug 28, 2009 | Apple iPhone Smartphone
    How to change the simcard of my apple 3g iphone?
    The SIM card in the iPhone is removable, but it's hidden. To remove the SIM card, you need a paper clip.
    We are checking to see if this voids your iPhone warranty. If you are concerned that it might, please don't perform this task.
    The iPhone's SIM card is located behind this door.
    1. Locate the SIM Card Slot
    The slot is located at the top of the iPhone, between the headphone jack and the power button.
    The paper clip is a valuable tech tool.
    2. Open the Slot
    Take your paper clip and insert it into the little hole. Then firmly push down until the slot pops up.
    3. Remove the SIM Card
    The SIM card is in a cradle. You can pop the card out of the cradle.
    To replace the SIM card, put the card back in the cradle. The cradle and card are notched in a way that forces you to replace the card on the proper side. Then just slide the card back into the iPhone.
    Thanks alot,
    Sanjeev Kumar
    Jan 22, 2009 | Apple iPhone 3G
    Cell Phones Logo
    44 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
