Question about DeLonghi DEBIGE 2440 Electric Double Oven
Delongi over nobs
My oven and burner nobs are metal and heat up when the top oven and grill are on. Is this a problem which can be solved? I bought a house and the Cooker came as part of the deal. I have been into Commit and the nobs look identical but are not metal and yet mine are.
  • ruth Hutton Aug 08, 2007
    It is a double fan assisted Delonghi oven, with the grill inside the top oven.
  • 3 Answers
YOU SHOULD NOT HAVE HEAT COMING FROM YOUR OVEN DOORS. MAKE SURE GASKETS ARE INTACT AND YOU OVENS ARE LEVEL.
Posted on Dec 17, 2008
SOURCE:
Creda oven manual
The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
May 10, 2014 | Ovens
Oven wont turn on
I have a delongi oven and hob hob is working fine but the oven isnot im turning the nob on the front of the oven and ignition on lighting is fine after I release the knob on the front the supply turns striaght off no flame no gas nothing
Apr 04, 2011 | DeLonghi Ovens
Simpson Harmony Nova Thermaflow Oven (63B906W) won't heat up
Hello,Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
May 26, 2010 | Ovens
Gas oven does not heat up
There is a very good possibility that your ignitor, which lites the gas supply is not working. Disconnect the electrical power and remove the floor of the oven, you may have to remove some sheet metal screws to do this. you will see a U shaped pipe with small holes in it this is the burner, at the back side of it and likely on thr right side (your left ) you should find a U shaped ceramic gizmo about 2 inches long which lites the gas burner. It will have two wires connected to it.This part can be bought online for 20 some dollars and is quite easy to change.Check any of the" applianceparts .com sites "you will find what you need at a good price. Give it a look, if you can do it your self ,you save and learn at the same time. Good Luck. superg
Jan 05, 2010 | Whirlpool Ovens
My Delongi dsf905 oven stopped working
FIRST CHECK THE FUSE IN YOUR PLUG IF OK THEN IT MIGHT BE THE TERMOSTAT IS FAULTY CHECK THE ELEMENT IS NOT BURNT OUT IF SO REMOVE AND BRING TO A ELECTRIC AND PLUMMERS SUPPLY STORE FOR REPLACEMENT.
Nov 29, 2009 | Ovens
I have a very old tricity double oven with a top part and bottom part of the oven it doesnt have a hob as thats separate.It has three nobs to the left that are for the grill, the lower oven and the main...
I think I might have a manual for this oven! Is it a built-in job with the grill at the bottom and main oven at the top, made by Thorn Tricity?
Aug 07, 2009 | Ovens
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
DeLonghi DEBIGE 2440 Electric Double Oven Logo
128 people viewed this question
Top DeLonghi Ovens Experts
Jason Harris
Jason Harris
Lollo Pop
Anthony Ward
Anthony Ward
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
