Sony kv-21GMR1MKII,tv no power - Televison & Video
ANU KAYA PROBLEMA NG SONY KV-21GMR1MKII, PUMUPUTOK ANG FUSE KC? PLEASE ANSWER MY QUESTION PO OR SUGGESTION
Posted on Jul 30, 2013
2 Suggested Answers
Sparko1
  • 167 Answers
SOURCE: SONY KV-32S25 TV SHUT OFF...NO POWER NO SOUND
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Posted on Aug 03, 2009
Sony sony kv-25v25 no power
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 14, 2014 | Sony KV-27V55 27" TV
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony KV 27FS16 TV does not power on
The chirping is the power supply trying to start. This is not a repair that I would recommend a novice attempt. PLease have this unti serviced. Expect a parts cost in the $20-$40 range for power supply caps.
Dan
Aug 31, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No Power Problem with KV-27s15 Sony TV
Barry, remove the back cover by removing the screws with an arrow next to them. The fuse is located on the left side as viewed from the back, where the power cord connects to the circuit board.
Aug 09, 2009 | Sony KV-27S15 27" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Berndulay@yahoo.com
Accroding to your model number:(KV-...) In sony tv units power supply porblems is very low unless a power surge.
You have to check these things.
1. Stand by 5V available or not
2.If stand by 5V available press power and check B+ is getting or not
3.If B+ available check Horzontal oscillation
4.May be H-out transistor or video amplifier is bad.
Oct 14, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony WEGA® KV-BM142M40
press sequently (1) display (2) 5 (3)volume+(4) power or TV when tv in standby mode
Nov 11, 2007 | Sony WEGA® KV-BM142M40 14" TV
SONY TV WON'T POWER UP WHEN COLD.
as there is a problem of any electrolytic cap in tv as per what you say. but in my opinion it might be taking time to crt glow due to low supply or its ageing.
Sep 22, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
