Net cut can not detect adapter
What does the light in the middle mean because mine wont stay on?
It simply tells you that no other powerline devices detected on the powerline network.
You may refer to this image link.
http://fixya-by-mongkey.webasyst.net/DD/html/scripts/getfolderfile_zoho.php?DL_ID=NDA%3D&ID=9d7fc82bbbc20e37c33bce11d86a0f65&DB_KEY=TVIxOTIx
or this manual link.
ftp://downloads.netgear.com/files/XE102_UM_8Jun07.pdf
I hope this answers your question.
Mongkey
"Understanding explains better..."
Jan 22, 2011 | NetGear Powerline XE102 Ethernet Bridge...
HP 530 wireless will not pick up any wireless networks. Please help
Hi.
First ensure that the wireless adapter is turned on.
If the adapter is on and does not detect any network, reinstall wireless network adapter drivers. the drivers can be obtained using the link below.
Download drivers and software
Reinstalling driver software usually fixes the problem, if it does not it usually means that the internal adapter is defective, in that case you will need to use an external wireless adapter (USB).
Sep 27, 2010 | HP 530 Notebook PC
My wireless adapter cannot detect any wireless network
Wireless adapters come with an installation disc.Uninstall the wireless adapter and then reinstall it,this should start the ball rolling,but some wireless adapters must use a wireless router plugged in to the main phone socket via the filter RJ11 PLUG,OR RJ45(A SLIGHTLY BIGGER PLUG)WHEN YOU SET THIS UP THE ADAPTER WILL PICK UP THE DATA FROM THE ROUTER,AND YOUR ON THE INTERNET.WIRELESS ADAPTERS WON'T RECEIVE ON THEIR OWN UNLESS YOUR NEAR A PICKUP STATION LIKE AN INTERNET CAFE OR A RAILWAY STATION.Go to an electronics shop like MAPLINS,and buy a wireless station detector.Then you will have to pay about from .99p to log on to a wireless cell..99p will give you about an hour on the net.GOOD HUNTING.
Aug 09, 2010 | IBM Intel PRO/Wireless 2100 MiniPCI...
I GOT NET CARD OF MODEL USR 7900 OF U.S.ROBOTICS I DONT HAVE THE INSTALLETION CD. SO FROM WHERE I CAN DOWNLOAD THE DRIVER FOR THE SAME
Go to this page, and read it, checking if it's the proper model's page.
Download the driver, unzip it to some folder and point the "new hardware wizard" to that folder when it detects your card. If it doesn't any more, go to Device Manager, open Properties of your already detected earlier card, find an "Update driver" button on a proper tab, and point to the folder where you unzipped the files.
Link: USRobotics support page
Nov 28, 2009 | U.S. Robotics USR-7900 (5 Packs)...
My laptop computer says the adpter is not detected we have ran th
You can connect the Cat 5 cable from your laptop to one of the ethernet ports from router to download. Or download from any computer to a  Jump drive then install to your lap top.
Sep 08, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
Cannot install my wireless lan card
did you go to dell and put in your serial number / service code?
Apr 15, 2008 | Computers & Internet
No connection
the 2wire will most likely have wifi security setup so you cant connect to the net with your pc til you configure the wifi key into the pc. The key will most likely be on a sticker on the underneath of the router.
Feb 10, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
