Question about Kirby G4 Bagged Upright Vacuum
When attachment hose is on, it's extremely loud
When the attachment hose is on, it's extremely loud and smells like something is burning. It does not make this sound when the main head is on though. Any ideas as to what it could be?
That only happens to me if I leave the vacuum on the carpet and don't raise the head before 30 seconds...it is the rubber belt hanging on the metal thing that it sits on. Since the belt is not used with the hose attachment, I cannot imagine what is going on. Therefore, I've been no help at all! Just to let you know it happens to others - just slightly differently.
Posted on Aug 08, 2007
SOURCE:
Kirby made a loud clunk then got real loud
You will probably find that you have lost fins off the fan at the front where the belt runs. Remove the head and look.
Mar 30, 2018 | Kirby Vacuums
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
My dc24 has started making a loud noise which seems to be coming from the ball. I switched its off when it started to smell of a slight burning or warm smell. Vacuum is only 2.5 years old, filters are...
Sounds as if there is something stuck in the vacuum causing the beater bar to stop turning while the belt continues to turn giving off the burning smell.
Oct 27, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Kirby G4 running very loud and smells hot.
were you put the belt on see if any thing is rubbing against shaft.it may have been the belt,replace the belt and clean out the bab and also the floor brush.
Jul 31, 2010 | Kirby G4 Bagged Upright Vacuum
My Eureka capture bagless vacuum has just started making a loud siren like sound. It is deafening. what is the problem?
does it smell like burning rubber if not check beater brush it sounds like something may be jammed in it or near where it goes up past beater bar into the vacumn inlet if you do have a burning smell the motor shaft is spinning and thinning the belt and may also be making that sound as shaft spins on loose belt
Dec 26, 2009 | Eureka Capture Upright Vacuum Vacuum
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
No suction, burning smell, expells dust
If by "suction" you mean it's not picking up dirt and debris on carpet, odds are your belt needs replacement, and the belt has burned, causing the burning smell. Ensure that your brushroll spins free, and replace the belt. (Belts should be replaced in any vacuum with a rubber belt every 3-6 months, regardless of use.)
If you mean that you are not having any airflow at the end of the hose, you most likely have a clog in the main hose and the burning smell is caused by your motor overheating. Ensure that there is nothing blocking the hoses.
If you have suction in the hose, and your brushroll is turning, there may be a clog in the head area behind the brushroll. Look in the hose that your wand plugs into, and ensure that it is also clear.
-R
Aug 05, 2008 | Eureka Vacuums
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
178 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
