Question about American Diagnostic Corp ADC Advantage 6014 Advanced Automatic Digital Blood Pressure Monitor
Clear memory 6021 - American Diagnostic Corp ADC Advantage 6014 Advanced Automatic Digital Blood Pressure Monitor
The ringer on my Nokia 6021 has stopped working. vibration mode works okay and can makes calls okay. any ideas?
Every so often a Nokia 6021 Phone will cease ringing and /or vibrating when there is an incoming call, although the call is displayed fine on the screen..
The problem is caused by a software bug and I find it sad Nokia have not resolved this as it has been present for years now..
To clear the problem, Cold Boot the phone by removing then replacing the battery. However in time the fault will eventually return.
Simply switching OFF, then ON , (Warm Boot) will not clear the fault.. Good Luck - Mike
Dec 16, 2010 | Nokia 6021 Cellular Phone
MODEL NOKIA 6021 CONTACTS STORED IN PHONE MEMORY DELETED BY MISTAKE HOW CAN I RETRIEVE IT?
H,
Once you delete the phone numbers from phone then it is not possible to retrive the phone numbers.
If you saved the numbers in SIM card then you can copy to phone memory.
To copy contacts from SIM card to phone,Contacts > Copy. You can copy names and phone numbers from the phone contact memory to the SIM card memory or vice versa.
Thank You
Aug 11, 2010 | Nokia 6021 Cellular Phone
Asking puk code nokia 6021
my security is blocked and its asking for a puk code
Sep 10, 2009 | Nokia 6021 Cellular Phone
6021 nokia insert sim
nokia 6021 sim ic jumper
May 06, 2009 | Nokia 6021 Cellular Phone
Message Contact service Nokia 6021
It sounds like it has gone into secure mode...have you entered any codes unsuccessfully into your device before it did this? If you entered any codes in before this happend and you have turned off your phone and turned back on and it's still doing the same thing..unfortunately anything you saved to your phone is a loss cause.
Feb 11, 2009 | Nokia 6021 Cellular Phone
Nokia 6021
Take it to your service dealer and ask them to test it and if possible to retrieve your data. Sometimes they will be able to make the phone work long enough to be successful. You will likely have to replace the phone anyway, so this process will relocate your numbers to your new phone if successful.
Nov 01, 2007 | Samsung SCH-a670
American Diagnostic Corp ADC Advantage 6014 Advanced Automatic Digital Blood Pressure Monitor Logo
80 people viewed this question
Top American Diagnostic Corp Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an American Diagnostic Corp Health and Beauty Expert? Answer questions, earn points and help others
