Question about Health & Beauty
2008 Vento Triton GT5 Turbo Cam
When I hit the throttle it shuts off.
3 Suggested Answers
  • 139 Answers
SOURCE: what type of oil is used for the 2007 vento triton r4
Hi Todd
The tank next to the gas tank under the seat is for two stroke oil, any high quality or brand name motor cycle two stroke oil eg. Castrol 2T (Jaso FB) classification.
Gear oil is SAE 85W/90 (API classification) capacity of 100ml.
Check this link for workshop manual. http://www.49ccscoot.com/manuals/Vento_Triton_R4_Service_Manual.pdf
I hope this will help you.
Regards
Phillip
Posted on Apr 12, 2014
  • 14585 Answers
SOURCE: Will a 2008 3.2lt turbo diesel triton engine fit into the 2005 triton engine bay (on the 2.8lt engine mounts) easy or not? Both daul cabs both 4wd both man
Probably will. But The computer system and wiring will not work on the 3.2. Before you start ripping out computers and wires. You need to make sure that both vehicles had the same transmission. If not, then your transmission won't work with the 3.2 computer.
Posted on May 15, 2016
My Honda EB3500X Shuts off when auto throttle is switched on making me run full throttle at all times. Cause? Solution?
if your engine shutting down, then your auto throttle is working.
when you hit the switch watch the throttle arm move on the carburetor to the idle position,if so you may have to clean the carburetor jet and fuel nozzle ports.possibly this occurs when unit has been stored for quite some time.once jets are cleaned it should maintain idle.
May 31, 2014 | Honda Eb 3500 Generator
Where is vento gt5 choke located
If the fuel tank is mounted below the carb, a fuel pump will be utilized since gravity won't work. You may be able to take a syringe & spray a little gas in the carb & see if it will run long enough to get it all primed up. Be careful with the flammables.
May 19, 2014 | Vento HipHop Motorcycles
When i hit the throttle the engin bogs down and shuts off
I'm pretty sure it's the throttle body sensor, could be wrong but am pretty sure. Had the same problem on a '96 Cavalier.. hope this helps..
Apr 19, 2014 | Hyundai Motor 1997 Tiburon
What type of oil is used for the 2007 vento triton r4
Hi Todd
Regards
Phillip
Apr 11, 2014 | 2007 Vento Triton R4
Honeywell thermostate will not kick off on set temperture
There's a "throttling range." The unit starts (say, in heating) one degree below setpoint and shuts off two degrees above set point.
You can change the "temp" but you can't change the throttling range.
Mar 02, 2014 | Honeywell Programmable Thermostat Heater
I think the accelerator for vento scooter is stuck and when it shuts off makes a weird noise
You should know it if the accelerator (throttle) is stuck. If the throttle moves freely and the engine responds, it's not stuck. If the engine doesn't respond to input from the throttle it needs to be thoroughly checked from the throttle assembly on the handlebars to the carburetor. A corroded, kinked, or frayed cable can cause the throttle to stick. DO NOT RIDE WITH A STUCK THROTTLE! If it does hang wide open, hit the kill switch immediately and sort the issue out before trying to start the scooter again.
Jan 06, 2014 | Motorcycles
Scooter runs but bogs down when given throttle 2007 triton vento scooter will run bogs down when given throttle
Make sure the air box is installed and the snorkel is on the air box and that it's in good condition. They don't run well or sometimes at all beyond idle without the air box. Could also be a clogged main jet or otherwise dirty carburetor.
Oct 26, 2013 | Motorcycles
Why does my vento gt5 backfires when trying to start it
fuel stavation carbs may need cleaned or petcock
Sep 12, 2013 | Vento Motorcycles
Health & Beauty Logo
43 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
