Question about Garden
Co op rear tine tiller - Garden
pranaclimbin
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
steve_lima
  • 181 Answers
SOURCE: what type of lube is used in 917-294261 tiller gearbox?
80-90 gear lube
Posted on Jan 09, 2009
  • 10865 Answers
SOURCE: Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Posted on Apr 25, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
Feb 23, 2011 | Craftsman Garden
I'm looking for blades for a tecumseh 5.5 formula, can you guys help me?
Copy and past this into your browser's address bar. Then hit enter! Tecumseh parts galore!
http://www.m-and-d.com/scan/se=TECUMSEH/sf=category/st=db/co=yes/op=eq/sp=brands_results/va=category_name=TECUMSEH/tf=sku/ml=20.html
May 10, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Ariens rear tine tiller. What direction are the
The tines should turn counter clockwise or from the ground up toward the tiller not toward you .Owners manuals can be obtained from a local dealer on most often on line..
Apr 09, 2009 | Ariens Garden
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy tiller tines
they should point inwards and towards the rear of the machine
Oct 17, 2008 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
