Question about Kenmore 44072 Front Load Washer
Kenmore 44072 Front Load Washer help
After hitting the start button, the machine spins for about 20 seconds then it stops for about 10 seconds. It will spin again and continue in this way until it completely stops and displays an f03 code. It slower than normal. On the drain spin cycle, it display 15 minutes estimated time. The timer does not activate and after around two minutes, the machine stops and gives the f03 code.
My kenmore washing machine has the timer out of time
Posted on Dec 23, 2007
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
The only spot my washer works is drain & spin every other spot it starts water for about 1 second &kicks off all lights except for no spin
i suspect a faulty wireing on this machine,and will need tested by an engineer a this could be dangerous.adrianxxx
Nov 15, 2012 | Kenmore 44072 Front Load Washer
Kenmore 417-48102701 front end loader washer. Won't go into spin cycle? Any thoughts of what to look for?
could be a number of problems,but try this FIRST push and hold any two buttons in for about 20 seconds make sure the machine is on,if this fails then you could have a blocked pump ie a sock is the usual suspect some mackines have a filter at the lower front check below the door if there is one then open and unscrew anty clock wise,if not then the pump will need removed and unblocked.adrianxxx
Jul 24, 2012 | Kenmore 44072 Front Load Washer
Where is the filter on my Kenmore 44072 washer?
you have a sock or simler item stuck in you pump .adrianxxx
Jun 19, 2012 | Kenmore 44072 Front Load Washer
Kenmore front load washer does not run final spin cycle
Try cleaning the filter and make sure you use correct amounts of HE soap
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 01, 2011 | Kenmore 44072 Front Load Washer
WHEN I PUSH THE START, NOTHING HAPPENS,NO NOISE AND THE DOOR DOES NOT LOCK. IF I PUSH THE CLEAR BUTTON TWO -- WILL APPEAR AND STAY FOR ABOUT 30 SECONDS AND THEN A BLANK DISPLAY. UNPLUGGED WASHER FOR 5 MIN....
if you had a power failure latly or a power surge it might have knocked the program on the machine.Push and hold the stop/start button for about 10,seconds it should reset if that fails again hold the stop button and another ie rince hold/power save or whatever buttons you have i just cant remember which one there are so many,but try the first option first it should reset.adrian,,,,,,,,
Aug 15, 2010 | Kenmore 44072 Front Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Kenmore elite front load washer
Make sure they didnt lock the control panel if it just beeps when u press buttons that might be it. there is a button u can press and hold for 3 seconds to lock and unlock the control hope that helps
Mar 13, 2007 | Kenmore 44072 Front Load Washer
Kenmore 44072 Front Load Washer Logo
264 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
