Question about Watches
How do you set the alarm on a roots watch, model RY2202
How do i set my digital watch,roots ry2129
Here is an actual 'live' web link (I just checked) - to Roots, "watches":
http://usa.roots.com/on/demandware.store/Sites-RootsUS-Site/default/Search-Show?q=watches&simplesearch=
If nothing else, if you scroll to the bottom their contact info appears which I am also pasting below. Good luck to you!
Contact Us:
• 1-800-208-0521
• Outside of Canada: 1-972-265-4120
• Email: onlineservice@roots.com
Nov 09, 2014 | Watches
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    How to set alarm on oots MAI TAI RY2142 Watch for Women?
    Start by holding in the mode button (bottom left) until the first number blinks, then let go. You are actually in the alarm mode right now. Now press and release the start/stop button (top right) and the minutes will flash, again for hours. When the parameter you want to adjust is flashing just press the adjust button (top left) to change the numbers. When your finished simply press the mode button to exit the setting menu. To turn the alarm and/or the hourly chime on or off, hold in the adjust button (top left) and press the start/stop (top right). Each time you press the start/stop (top right) the CH or AL or both symbols. When the symbol is showing, that function is on.
    Jun 02, 2014 | ROOTS MAI TAI Ry2142BLK Watch
    How to change time on roots watch ry2203
    Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
    Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
    I need to set an alarm on my watch but I do not know how. I have a Baby G watch Casio Model BG169A-1AV
    press mode until you reach the alarm mode then press and hold set button until the digit blinks. note: the one that blinks can be adjusted, the 24 hr/fwd is to add, the alarm on/ rev is to minus. if your done press set button to finish. i hope this will help you.
    Jul 13, 2011 | Casio BG169A-1AV Wrist Watch
    How to set Seiko alarm chronograph alarm?
    Without the watch model it is hard to help you set the watch. Some Seiko watches use the watch stem which has two positions. Sometimes it is hard to identify the indentations so you may want to pull the stem all the way out then carefully push the stem to the first indentation. This will activate the alarm until it is pushed all the way in. When it is in the alarm on position, you can use the buttons to set the alarm time. However, I have 10 Seiko watches, and they are all unique to their functions, so it is best that you go to the link below and put the caliber code from the case back and look at the instructions.
    http://www.seikowatches.com/support/ib/index.html
    Feb 24, 2010 | Bulova Watch
    How do you set the time on the Roots Womens's Mai
    Feb 05, 2010 | Watches
    Need to turn off alarm
    A model would be most helpful here. Timex has a couple different alarm set ups.
    With most of their watch if you cycle through the modes using the mode button you will come to alarm. Depress set and the alarm will toggle on or off.
    With Dial alarm models you simply depress the alarm button (the one with the red stripe).
    Sep 18, 2009 | Timex Watches
    Set the alarm
    To turn the alarm off press and hold st/stop and then press lap/reset. To set, press the lower left hand corner button, you will see the option to set the alarm first and then the option to set the actual watch time.
    Apr 10, 2009 | Watches
    Alarm goes off at midnight & repeats for half hour, and not set
    what you have to do is
    1. press the mode button until you get to the setting that has "AL" at the bottom right.
    2. then you press the "receive" button to switch between the four alarms.
    3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
    4. repeat step fout for all of the alarms, and the problem should be fixed.
    Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Watches Logo
    345 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
