Question about Garden
Need to change the battery on my mtd yard machine 638rl. How many cranking amps do I need?
3 Suggested Answers
  • 5 Answers
SOURCE: oil change
if this model has a fill tube on it- turn the unit on its side to drain.
Posted on Feb 06, 2009
SOURCE: HI I have a (MTD) YARD MACHINES 638RL I would like
rider wont start just spinning as if it wants to start been sitting 5 months
Posted on Aug 03, 2013
Need help MTD Yard Machines 638RL 13AM762F0521680563
Constance, it sounds like you may have sheared the flywheel key. if the engine turns over but wont start i would take the covers off the engine and check to be sure the key is still in position. if not replace it. there are videos on you tube that show this process. be sure the blades are able to move to the free position also. if something is jammed the belt or blades it may not allow the engine to start.
Mar 31, 2018 | Mtd Garden
I have a Yard Machines Mtd 22 pushmower and the model number has been worn off. I need a manual for it but the web site requires a model number.
A lot of machines are generically produced. MTD is made in the same factory as: Craftsman, Cub Cadet, Some John Deere, Green Machine, Yard Machine, etc.
So if you find a comparable model to yours, that manual may suffice for the part you may be in search of???
Go to your local DIY center, take a picture with your phone, of the name, & S/N tag of a mower similar to yours.
You may get lucky with a Craigslist Seller of a 22" MTD to give you the appropriate numbers? Just trying to assist you.
Try here
Free User Manuals ManualsOnline com
Or here...
Operators Manual
Apr 11, 2015 | Mtd Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
I would like for my mtd 638rl to keep running when i put it in reverse without stopping the cutting blade. Please help me, tks cliff
should be a switch under the shifter that is pressed in when you put it in reverse. disconnect and jump the wires.
Jul 09, 2011 | Yard Machines 155 Torque Briggs Stratton...
What does it matter how much they cost. Go to the home depot of the like and buy new blades if you need them. Most of the time all you need to do is sharpen them did you go that route yet??? Lefty loosy righty tighty...
Sep 18, 2010 | Yard Machines 46" Tractor Mower Blade Kit ...
Need wiring diagram
There is a safety switch under the seat as well as attached to the clutch pedal
Jul 26, 2010 | Yard Machines 155 Torque Briggs Stratton...
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
How do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
Jul 08, 2009 | Mtd Products Yard Machines 158CC Tiller
I HAVE A 660 SERIES MTD YARD MACHINE 17.5HP 42
If the speed seems to be different after changing the belts, it should return to normal after they break in.
The 600 series has a top speed of about 5 - 6 MPH, see:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=79&p_created=1027096447&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=68&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTYsMTYmcF9wcm9kcz0zMDEmcF9jYXRzPTAmcF9wdj0xLjMwMSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXNwZWVkIGNvbnRyb2w*&p_li=&p_topview=1
Apr 24, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
