Question about Electrical Supplies
2 single pole switches each controlling bathroom light and fan
What is the correct way to wire them so each switch controls light & fan seperately. I have 1 power cable coming from a ciruit breaker (blk, wht, gnd), 1 cable going to light, & 1 cable going to fan. My bathroom switches were working fine for so many years. And one day, suddenly stop working. (Same time, one of bedroom wall switch stopped working. I checked again this morning & it's working fine) I don't remember the original wiring of bathroom wiring; I don't remember changing any wires... Currently, all GND wires are tied together and conected to GND screws of each switch. All Nutural (wht) wires are tied together. Hot (blk) wire is connected a screw of switch and blk wire to fan is connected to another screw of switch. Same for light switch with hot (blk) of fan and light wires are tied together. When circuit breaker is turned on, I see hot wire is hot, yet when I turn the switch on, nothing happens. Is this wiring correct? Should I replace the switch? Thank you in advance for your help.
4 Suggested Answers
  • 10865 Answers
SOURCE: 2-wire pull chain switch wiring in a ceiling fan light kit
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
Posted on Jan 22, 2009
The Duff Man
  • 3 Answers
SOURCE: ceiling fan pull chain switch replacement
Just take either one of the black wires from the switch and connect it to the group of black wires. Then take the remaining black wire from the switch and connect it to the single black wire coming into the light kit. Finally check the bulbs to be sure they're not burned out.
Thanks and good luck
Posted on Jan 24, 2009
  • 547 Answers
SOURCE: bedroom light not wired correctly...need help.
white wire cut in half attach white wire to switch both screws attach ground to box blach wire just runs through
Posted on Feb 18, 2009
Separate 1 switch 3 lights
You need separate wire going to each light.
Here are diagrams:
2 single pole switches, before you started to replace
Single pole and 3 pole to control each light separately: must identify black wire to each light. If each light does not have separate black wire inside the switch box, then it is not possible.
Add a comment
Jul 05, 2013 | Electrical Supplies
I am trying to install a Pass & Seymour Harmony fan speed control switch. It has 2 red wires and 1 black. I hooked up the power to the red line and the black leading to the wiring for the fan. No...
Are you wiring for 3-way or single pole?
In other words, are you using 1 switch (single-pole) or 2 switches (3-way)
Before installing device, separate all wires in box and turn power on and then test each wire to bare ground wire >> tester will light up on Hot power source.
Black wire on device is connected to Hot power source.
Red wire on same side of device as black wire is capped off in single pole application.
Red wire on other side of device from black wire goes to the fan motor.
Green wire is ground.
Set fan on highest speed before connecting red wire to fan, and then do not adjust fan speed using pull chain.
I am unsure what volt-amp-testing will show for power output on either red wire, but certainly it will vary as the switch is adjusted to each speed.
Call 800-223-4185 for Legrand tech support.
Sep 25, 2012 | Electrical Supplies
Hi *****,
I'm an electrician and can help you with this problem. First - shut off the power. Check your wiring as I describe the connections below.
If this is the only switch operating the fan and light, it should be wired as a single pole in the direction sheet. That is as follows:
1) one black wire - it should be connected to the "hot" power source, 2) one green wire - it should be connected to the bare / green ground wires & switchbox (if metal), 3) one red wire - it should be connected to the fan hot wire, 4) one yellow wire - it should be connected to the light hot wire, the remaining wires (yellow with a "3 way label" and red with a "3 way label") should not be connected to anything and capped with a wirenut.
The wiring changes if you are using a second switch to operate either the fan or light (download & view the wiring diagram provided here to follow along with my text). In this case, the hot wire from the fan or light would connect to the black screw of a standard 3 way switch, and the remaining two terminal screws on the switch would connect to the red / red with 3 way label - or yellow / yellow with 3 way label pair. Power and ground wiring on the dimmer black and green are the same as the single pole wiring described above.
I hope this helps & good luck!
Jul 08, 2012 | Electrical Supplies
What is the correct way to hook up a TM813-WCCS? I have one lead from the downstairs 3-way switch - black/red/white, and a fan lead - black/white. I can get the 3-way switches to work, but no luck adding...
Not enough information is given.
TM813 is combo switch with single-pole and 3-way. So switch has two different rocker-switches on face, and one controls 3-way circuit and one controls single-pole circuit.
You are controlling a light and a fan.
You have successfully connected lights to 3-way switch.
Are you trying to connect fan to single-pole switch?
Add a comment and say what you are connecting, and what type of switch you are replacing, and what each wire tests, and what terminals are on switch and what wire you have connected to each terminal so far.
Jul 10, 2011 | Electrical Supplies
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
Fan pull-chain wiring shows following link:
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
We have the slider lutron dual fan control/light dimmer single pole switch and need to install it to work with our fan/light combo which also operates with a remote. How do you install the combo switch? We...
I don't think you can do what you are trying. The fan & light are on one circuit. Probably, originally, there was only a light fixture there. The fan/light is on a single circuit and the remote does the controlling of both units.
Now, you are trying to install a fan control and light dimmer but you don't have wiring for each separately.
You might be able to use one of the dimmer controls to adjust the output to the fan/light combination, but you can't control them individually, if I understand your wiring.
Dec 19, 2010 | Slider Lutron: Dual Fan Control / Light...
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
My Lutron Rotary Fan Control FSQ-2FH-DK. The box saye can be used for a 3-way as well as single pole, I want to wire it as a 3-way but the unit has only 2 black wires and 1 green wire. how can I wire this...
I don't think that model is for a 3 way switch . It is for fan speed control only. Green is ground, and one incoming and one outgoing "hot" wire. You will need a different part number such as:
Oct 09, 2010 | Lutron FSQ-2F Rotary Fan Speed Control,...
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Trying to hook up a Lutron fan control and dimmer
The old switch is just a single pole switch. The new one is for fan speed control. You need to use a regular single pole switch like you had. Or you can use a single pole switch on the Lutron you bought if you can figure out which wires to use. Do you have a meter?
Jun 27, 2009 | AMS Lutron S2-LFSQ Skylark Dual...
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
