Question about Amana NTW4500V Washer
AMana washer NTW4500V
Will not spin water out
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Posted on Feb 21, 2007
  • 18 Answers
SOURCE: Washer wont work.
try putting it on spi - do you hear anything? could be a broken belt - very easy to fix.
Posted on Aug 26, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Amana washer would not
Hello there
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician. It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Dec 20, 2010
Filled with water. Took towels out - would not spin. Unplugged it. Now it tries to drain but stops and lid unlocks.
Amana , Whirlpool Washer Repair - Not spinning or draining ...
? 1:50
www.youtube.com/watch?v=q7ey58YZrm8
Jul 2, 2013 - Uploaded by ApplianceVideo.com Repair your own Amana Washer with these following issues: Not ... How to Fix a Washing Machine That Does Not Spin (Fast and Easy) ...
Sep 17, 2015 | Amana Washing Machines
Water
Is water turned on ??? If so, could be cold water valve faulty
Jun 16, 2013 | Amana NTW4500V Washer
Hello. I have a Amana top laod washer. My washer will spin(i can hear it spin and see it shakes as it spin). My washer will not fill with water when I turn it to a washer cycle. No water will fill in this...
If you're not getting any water (hot or cold), you'll need to check voltage coming to the solenoid valve. This is the valve the hoses connect to on the back of the washer. If you're not getting voltage during the fill cycle, your timer is the most likely culprit.
Jan 01, 2018 | Amana Washing Machines
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Nov 28, 2010 | Amana Washing Machines
Inside of washer smells bad!!
Your smell is inside the washer under the cabinet. You must take the cabinet apart and thoroughly clean it. You must have a small leak that has been going on for sometime now for the moister has mildewed. Lysol will kill the smell on this although it must be cleaned first of all
Apr 28, 2010 | Amana NTW4500V Washer
Washer wont work.
Feb 28, 2009 | Amana LW8203
Feb 20, 2007 | Amana ALW880WH Top Load Washer
Amana NTW4500V Washer Logo
20 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
