Question about Garden
Kohler engine model#cv490s
Engine starts , stalls when mower deck is engaged as if its running out of fuel . fuel flow to carb is good!
SOURCE: Stalling Briggs & Stratton engine
Try taking the air filter off ,start the motor and try it. If this works replace air cleaner element
Posted on Oct 05, 2008
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 127 Answers
SOURCE: john deere mower won't engage
on the engine there is a shaft with 2 pullys ,drive belt goes to the top closet to the engine lower pully is for the deck
there also is a saftey switch located on the deck which should shut down blade operation when raised. check the mandrels for broken bearings by grabbing the pully and wiggle them back and forth looking for movement could be possible that one madrel is shot giving you that bad sound which is crushed bearings
Posted on Jun 30, 2009
  • 61 Answers
SOURCE: I have a scotts (made
sounds like safety switch
Posted on Sep 06, 2009
RonInFla
  • 86 Answers
SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Posted on Apr 18, 2010
Testimonial: "Haven't tried the suggested solution but makes sense."
Kohler engine troubleshooting
Engine hunting is usually down to fuel starvation, this can be dirt in the carb, or the fuel pump is not working correctly, or the anti fire solinoid on the base of the float bowl is not working correctly, you can check the fuel flow from the pump by removing the fuel hose from the carb, place the hose in a suitable container now crank the engine, there should be a good flow of fuel, if so replace the hose, now remve the fuel solinoid from the bottom of the fuel bowl ( place a suitable bowl under the carb as there will be a flow of fuel) switch the igntion on, there should be a click and the small pin in the centre of the solinoid should retract into the housing, if this is ok then there is dirt in the carb so you will have to clean the jets in the carb itself.
Jan 23, 2018 | Husqvarna Garden
When trying to start fuel spits out of the carburator
Remove carb float bowl. Clean bowl. Get model no. of engine and get new float bowl gasket set at mower repair store. Ensure float drops down freely with float bowl removed. Push up on float to stop fuel flow. If not working properly replace float and meter needle.
May 31, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Kohler magnum 18 engine starts cold fine. the longer it runs the more choke is necessary to keep running. eventually when hot it wants to stall. also when going downhill it wants to stall. changed fuel...
01 Sounds like it is running out of fuel because it wants you to choke it to get more fuel.
02 Might have a restriction in a fuel line. Disconnect at carb and see if there is a good flow of fuel.
03 Loosen the fuel tank cap and see if the same thing happens. Cap might not be venting.
04 Any black smoke from muffler?
Apr 15, 2010 | Garden
Stalls when put in gear or engage mower
your lacking power and probably need to clean your carb or adjust the main idle screw..its on the botton of the float bowl...back it out a half turn...start with a quater..well its running
Jul 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower starts runs begins to back fire and run
Sounds like it is leaning out, running out of fuel. That can be the strainer at the gas tank, any fuel filters it has. Disconnect the fuel line from the carb and see how good the flow is to it, and check for water. A new spark plug never hurts.
Apr 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
