Question about Suncast Hosemobile-Pro Hose Reel Cart SFB205M
Suncast hosemobile parts list
Water pressure pushes the water supply hose out of the hosemobile. Is this fixable?
Keep getting a E4 Code
This E4 Phenomena means "no water":
No or slow water fill (not
reaching the full level in 15 min),
therby computer sends display message "E4"
Reasons:
1) The house water tap is not open, or
2) This is the most common E4 reason- The water inlet valve (that the hose is connected to) is blocked.
3) The water pressure is too low and the flow is too weak.
Solutions;
1) Open the water tap, then push the START/PAUSE button again.
2) Clean the water inlet valve. Shut off house water supply on the wall then, unscrew (lefty loosy) each hose from the house and the machine and look for a screen and clean the junk away from the screens. You may have 1 or 2 screens depending on the hose there may be 1 screen where the hose connects to the house and another screen inside the machine valve. Then, return hoses and turn on the water pressure again, Then push the START/PAUSE button again.
3) Wait for the normal water pressure to return to the house before use.
Oct 08, 2013 | Haier HLP23E Top Load Washer
Sportsman pressure washer
1. Check the power supply.
2. Check the water supply.
3. Inspect all hoses.
4. Take a look at the inlet valve.
5. Check the intake filter.
6. Inspect the nozzle.
7. Inspect the gun.
8. Check the power pump, unloader, regulator, and other valves.
Diagnosis takes this order because the things at the top of the list are more common and much easier to check. That's the good news when it comes to looking over your pressure washer. Most pressure and other performance issues will be caused by something small and simple like a clogged nozzle.
Even components like regulators and unloaders are fairly simple to replace, and can be done by confident workmen an homeowners. Once problems boil down to a power pump issue, it's usually best that the pressure washer see a shop.
Because the problems of and solutions to symptoms are so varied, we just list them below without any particular order, although we list the most common symptoms and causes first.
Honda Parts.
May 28, 2012 | Buffalo Tools Sportsman 1,800-PSI Gas...
The letters H and F keep blinking
The FH fault code means that there is a problem with the incoming water pressure for some Kenmore washers.
First, make sure that the valves to the washer are open. Close the valves again and remove the water hoses from the washer and the water supply. Check the filters for clogs and remove any. Some hoses will seal themselves if they detect a leak, so you may want to replace the washer hoses instead of just reconnecting them. Reopen the valves. Check if the code persists.
Do you have sufficient incoming water pressure to the valves? If the problem persists, then the valve inside the washer or the incoming pressure sensor has a problem.
If you add a comment with the model number of your washer, I may be able to provide more information on the issue. The parts list is probably available at Sears Parts Direct and the manual is likely to be at Manage My Life .
I hope this helps.
Sep 11, 2011 | Kenmore Washing Machines
I have the suncast model of hose reel that u have to manually wind. i tried to put a new hose in but it seems i loaded it wrong. When i went to use it the hose that hangs out that hooks to another would...
The hose on the side that connects to the water supply is not the same hose that goes inside.
The side hose connects to the faucet and the fitting on the hose reel is not supposed to rotate.
The hose that the homeowner installs connects to the adapter on the center of the reel and this goes around when the spool is turning. Beyond that, I don't really understand the question. Hopefully this will give you some information that you can use and then post back.
Gary
Apr 17, 2011 | Garden
Where is the Suncast Corporation Sierra 6ft. x 8ft. Resin Storage Shed Manual? I purchased the shed. No manuels or instructions in the box
Here you are. I hope your model is listed. I downloaded a couple of them. I don't know if you have the 6 X 8 or the 8 X 6. Both (with model numbers) are listed here. Adobe Reader is required.
http://www.storageshedsoutlet.com/suncastshedmanuals.aspx
Apr 05, 2011 | Suncast Garden
I have a Kenmore Elite HE3t washer. It fills up
Ironically, the "FH" error is called a "No Water Detect" error. It can have several causes however. The error can be generated if there's no water, or not enough water flowing into the washer. It can also be generated if there's too much water. The following link explains:
http://www.fixya.com/support/r3608753-fh_error_code
Since your washer is over-filling, I would strongly suspect you have a pressure switch malfunction or the air hose that runs from the wash tub to the pressure swtich has come loose. The pressure swtich is located in the the right rear area of the washer and is accessed by removing the top panel of the washer. There is a small air hose that runs from the switch to the bottom of the wash tub. This air hose is used to detect the pressure differential in the tub as the washer fills. The pressure differential is sensed by the pressure swtich and it shuts off the water supply to stop filling. I would recommend you follow this air hose all the way to the bottom of the wash tub to ensure it is still attached. If not, the tub will continue to fill as yours is doing. Reattach the hose as necessary if it has come loose and the poblem should go away. Make sure you check the entire run of the hose to ensure there are no holes as well. Leaks will cause the pressure swtich to malfuction. If the air hose is still intact, replace the pressure swtich. The part number for a replacement pressure switch is 8181695. If you need to replace the air hose, the part number is W10004260. You can purchase parts at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list offer helpful exploded view diagrams to assist you in part location/identification. The pressure switch and hose is listed under the "Top and Cabinet" heading if you search by model number.
The pressure hose replacement is simple. Make sure the washer is UNPLUGGED before servicing and disconnect the electrical connector plug(s) from the switch, disconnect the air hose and remove any mounting screws. Some of these switch are simply clipped onto the cabinet side.
If you have any questions about this repair, please post back and let me know. I hope this information helps you.
Dec 14, 2009 | Kenmore Elite 45986 Front Load Washer
Suncast Hosemobile-Pro Hose Reel Cart SFB205M Logo
69 people viewed this question
Top Suncast Garden Experts
Dennis Key
Dennis Key
john h
Are you a Suncast Garden Expert? Answer questions, earn points and help others
